could i get some diagnosis help. (VIDEO)
#61
hmmmmm....my buddy just finished installing his gsc s2 cams in his evo 9 and has the same noise. he also installed gsc valve springs. could it just be the nature of the cams with aftermarket valve springs?
his noise is on the opposite side as mine though, my noise is around cylinder 1 intake valves and his is around cylinder 4 intake valves
weird......
weird......
Yes mine does the samething
#63
#64
Have you tried a mechanic's stethoscope to pinpoint exactly where under the valve cover it's coming from? Definitely is from under there. You can probably rest your hand over it slowly moving around and find the source.
#65
my buddy recently installed his gsc s2 cams on his car and has the same noise. i have also found several videos with the same noise caused by big cams.
my local tuner also said it was normal.
plus it has died down a little. not as loud and barely noticeable.
mberenis
19
Aug 24, 2016 08:50 AM
KevOVIII
18
Nov 10, 2005 09:05 AM
BostonLancer
Lancer Troubleshooting
21
Nov 2, 2002 01:04 PM
