New BW EFR Turbo Thread
Old Feb 21, 2012 | 12:49 PM
  #1516
n2oiroc's Avatar
The drama is too much! for the love of god, does anyone have a well built car ready and willing to test a turbo? I have a ts 8374 ready to rock, but my car wont be ready for a couple months.
Old Feb 21, 2012 | 01:16 PM
  #1517
bolio's Avatar
this isn't the right setup to compare to the high # HTA86 turbos imo. Still dont understand we haven't got a comprehensive back to back test with the EFR ts turbos at full ew potential by retailers. The internal waste gated turbos with the smaller ar wont measure up. Why even go internal with a larger turbo?
Old Feb 21, 2012 | 02:03 PM
  #1518
user 72082032's Avatar
Originally Posted by Full-Race Geoff
it has way more in it. TQ dropped because the WG spring was too soft. im swamped this week, we will be back on the dyno to put a rest to this forum whining when I can.
dont forget this is only a 2.0L mild street build, .92 a/r internal wg. Daily driver meant for fun. NOT an 800hp turbo, thats the 9180 1.05 or 8374 1.05 maxxed out. lets be realistic
Would you say this is a better comparison to an FP black BB? That's kind of a 35 size compressor in a divided housing.
  #1519
Ludikraut's Avatar
Originally Posted by bolio
...Why even go internal with a larger turbo?
Less plumbing, no monkeying with external DVs, etc. Having seen Geoff's results, I'm seriously stoked for my application.
l8r)
Old Feb 21, 2012 | 02:36 PM
  #1520
03whitegsr's Avatar
Originally Posted by 94AWDcoupe
I think you guys will be disappointed when Jeffs setup is pushed harder. It looks to me like the setup is about done with the torque curve after 7 k. the internal gate housing looks to be choking things quite a bit. 560hp for 30 psi is also indicating this. I think leets car made 530ish at 24 psi on smaller turbo.??
I was somewhat excited about these turbos a year ago. been nothing but disappointed since
Engine VE curves usually don't have that pronounced of a knee in them when fully tuned like you see in his graph. IMO, it looks like there isn't enough timing advance in it and an optimized tune would probably produce a more desirable curve. Geoff said it himself, the tune wasn't really completed.
My posts honestly probably come across odd here as half the time I appear to be slamming Full-Race/Borg Warner and the other half the time I appear to be phrasing the technology they are using.
Simple truth is, I'm looking for factual data from them to reinforce their claims because I WANT to see the EFR line perform well. I'm biased towards seeing these work and I'm playing devil's advocate here.
Old Feb 21, 2012 | 02:47 PM
  #1521
MrLith's Avatar
We are in exactly the same boat, though I feel it has become a frustrating boat to be in.
Old Feb 21, 2012 | 04:15 PM
  #1522
R/TErnie's Avatar
My 7670 will be on a E98, 2.235L, 40+psi, vipec, cnc'd Evo 9 head, S3s, Magnus v5, 3.5" exhaust... the works. I think I'll be able to hit near 675 on a DJ. I will not ***** foot around.
Old Feb 21, 2012 | 05:29 PM
  #1523
jtothawhat's Avatar
ATTN: My EFR 7670 TS was stolen from my buddies shop in northern IL, please BOLO I have pictures upon request with some identifying markings.
Old Feb 21, 2012 | 05:49 PM
  #1524
MrLith's Avatar
Whoa cool, this will be very interesting to see - nice work and good luck. When are you going to do this?
Old Feb 21, 2012 | 06:00 PM
  #1525
n2oiroc's Avatar
atta boy! estimated completion date?
Old Feb 21, 2012 | 07:37 PM
  #1526
R/TErnie's Avatar
Short block is assembled. My head will be back from NC in 2-3 weeks and I'll be able to assemble the entire thing then. I've started fabricating a bunch of components now... converting to -8AN ss hardlines, Kinsler FPR, Wilson Fuel rail, ID2150's. I'm a busy boy.
Old Feb 23, 2012 | 10:13 AM
  #1527
Geoff Raicer's Avatar
found a hairline crack in my transmission case last night, i knew something wasnt right either the rebuild or the oem caused this. I will fix it asap, glad i didnt listen to you and put the car back on the dyno pushing it 100% yet.. I need to fix this trans case first then ill add my 2nd fuel pump and i will be on the dyno right after.
also - do any of you ECUflash gurus know if there is a new ecu-unocker other than V1.1?
Old Feb 23, 2012 | 10:15 AM
  #1528
MJ23FE's Avatar
found a crack in my transmission case last night, i knew something wasnt right either the rebuild or the oem cause this. I will fix it asap, glad i didnt listen to you and put the car back on the dyno pushing it 100% yet.. I need to fix this trans case first then ill add my 2nd fuel pump and i will be on the dyno right after.
x10
-Jalal
Old Feb 23, 2012 | 11:01 AM
  #1529
Me too i was on a website last night full of hairline cracks. Email me if you need any help.
Old Feb 23, 2012 | 11:11 AM
  #1530
Ludikraut's Avatar
Teh Interwebz was designed with them in mind ... they're everywhere ...
l8r)
Quick Reply: New BW EFR Turbo Thread
