New BW EFR Turbo Thread
Old Nov 28, 2012 | 03:08 PM
  #2266
R/TErnie's Avatar
Nope. Mine is a few months old.
Old Nov 28, 2012 | 07:46 PM
  #2267
evotris's Avatar
6266 vs EFR8374
Old Nov 28, 2012 | 07:50 PM
  #2268
khmerpimpin's Avatar
I want a SP Cutout!
Hm. they even put "spool data" but I want to see the transient response difference between the turbos
Then again, it is on a 6 cylinder car, I guess we might not see a huge difference?
Old Nov 28, 2012 | 10:13 PM
  #2269
03whitegsr's Avatar
Isn't Sound Performance a PTE dealer???
See...I can call bull**** for and against the EFRs.
Old Nov 28, 2012 | 10:42 PM
  #2270
URQaudiguy's Avatar
LOL, yeah me too.
Check out this twin turbo'ed EFR 7064s on .83 housings IWGs for a customer's 4.2L twin turbo Audi RS4 we supplied part for. Over 1000ft/tq at 3000rpm with still more room to go. Cams are limiting hp to 800ish. Vid is pretty fresh in the tuning, with cams there is still lots more headroom to go.
[youtube]http://www.youtube.com/watch?v=zOgeLYF5HdE[/youtube]
Old Nov 29, 2012 | 01:50 AM
  #2271
Talx's Avatar
ok people upload your turbo pictures from the latest batch.
let's see the T4 external WG as well.
Old Nov 29, 2012 | 08:44 PM
  #2272
wazzu70's Avatar
The BMW forum Bimmerforums has a thread about the new EFR turbine housings. I asked Full-Race for confirmation these were not counterfeit housings which they did. I then asked if someone could send me some pictures of the new housings so I could see what they looked like with the ceramic coating and all that. I also asked for pictures with the gasket held up to verify everything lines up since I was hearing they were off.
IMO the housings look just fine, and if you are thinking of not running an EFR turbo because of the turbine casting you are missing the point. The wheel aero, bearing structure, and turbine material are what makes it.
No affiliation with the vendor, just a person curious about these turbos and the turbine housing situation. I'm generally a lurker here so my name wont really be recognised, not trolling
Old Dec 3, 2012 | 04:40 PM
  #2273
Ludikraut's Avatar
Full-Race EFR 8374 IWG .92AR PICS
As promised ... pics!! Let me know if you want any particular angles/shots. If you want hi-res shots, PM me. I can e-mail them to you. This thing dwarfs my 50-Trim, LOL.
l8r)
Attached Thumbnails New BW EFR Turbo Thread-ludi_full-race_efr8374_iwg_92ar_01.jpg   New BW EFR Turbo Thread-ludi_full-race_efr8374_iwg_92ar_02.jpg   New BW EFR Turbo Thread-ludi_full-race_efr8374_iwg_92ar_03.jpg   New BW EFR Turbo Thread-ludi_full-race_efr8374_iwg_92ar_04.jpg   New BW EFR Turbo Thread-ludi_full-race_efr8374_iwg_92ar_05.jpg
Old Dec 3, 2012 | 04:41 PM
  #2274
Ludikraut's Avatar
More EFR goodness. As stated on Full-Race's website, the exhaust housing is coated with their silver 2000* coating. Looks pretty decent to me. We'll see how it holds up in actual use.
I'm still waiting for the manifold and other parts to come in. I don't anticipate having final results until late February/March '13.
l8r)
Attached Thumbnails New BW EFR Turbo Thread-ludi_full-race_efr8374_iwg_92ar_06.jpg   New BW EFR Turbo Thread-ludi_full-race_efr8374_iwg_92ar_07.jpg   New BW EFR Turbo Thread-ludi_full-race_efr8374_iwg_92ar_08.jpg   New BW EFR Turbo Thread-ludi_full-race_efr8374_iwg_92ar_09.jpg   New BW EFR Turbo Thread-ludi_full-race_efr8374_iwg_92ar_10.jpg
Old Dec 3, 2012 | 06:43 PM
  #2275
l8r)
Exactly what I want, and did you order from Full-Race directly or another vendor?
Old Dec 3, 2012 | 10:54 PM
  #2276
Talonboost's Avatar
Yeah actually that housing with coating looks not too bad. Not quite as many divots in the surface as the one posted by wazzu.
So let's see, from your 50 trim settup, you are changing over to a manifold for twin scroll ..... any other changes of note planned to your overall engine setup? What I'm thinking is, as I remember you had a GT3071 for awhile, then the 50 trim, now this 2 scroll EFR. If you aren't going crazy with cams and all kinds of other stuff you could make some interesting comparisons. BTW was your GT3071 with an anti-surge (ported) type compressor inlet or regular inlet?
Old Dec 4, 2012 | 06:47 AM
  #2277
Ludikraut's Avatar
I ordered from Full-Race - added my name to the list in May or so. But from the sounds of it, the turbos are finally starting to come in.
l8r)
Old Dec 4, 2012 | 06:54 AM
  #2278
Ludikraut's Avatar
Yeah, it should be a decent comparison. I run Kelford 272s right now, and I'm not all that excited about them. I may switch over to a set of GSC S2 cams, not sure if I want to risk a set of R2's as I think I will lose too much spool to make them acceptable. Things that will change with the EFR build are going to be:
- Radiator
- Ignition (going with Sparktech)
- Essex brake kit
- Cams (maybe)
- fuel setup
I'll have it tuned on 93 octane to get a good comparison to the 3071 (which was a regular inlet and sucked, IMNSHO) and 50 trim. Then I'll see what I can squeeze out of it on 100 octane. From what I've seen of Geoff's setup, I expect the 8374 to spool earlier than my 50 trim and obviously make a lot more topend.
l8r)
Old Dec 4, 2012 | 06:37 PM
  #2279
Talonboost's Avatar
the 3071 (which was a regular inlet and sucked, IMNSHO) l8r)
I remember that you had surge problems with the 3071, and that you liked the 50 trim better overall. Were they both in T3 hotsides with .63 a/r? Did the 50 trim spool up at about the same rpm that the 3071 did - just without the surge?
Old Dec 5, 2012 | 04:31 AM
  #2280
JARVEVO8's Avatar
It's aliveeeee!!!!!
BW EFR 7670
[IMG][/IMG]
Soon more details... I will dyno it next week.
Quick Reply: New BW EFR Turbo Thread
