New BW EFR Turbo Thread
Old Mar 5, 2015 | 01:32 PM
  #2911
Talonboost's Avatar
Originally Posted by Dave W.
It seems to be limited by the direct injection fuel system, too.
Do you know what the limitations are, that are caused by the direct injection system? I'm just curious, have been wondering about this ever since direct injection started popping up on the newer cars.
Old Mar 5, 2015 | 02:40 PM
  #2912
Dave W.'s Avatar
Originally Posted by alpinaturbo
Dave
Is that on efr8374 internally gated, on 91 octane?
The 435whp at 26psi.
On your Mustang, or DJ?
Coincidentally, yes it's an 8374 with an internal gate, open scroll T3 housing, unknown octane but not 91 and not leaded fuel. This is on a Mustang dyno in 2WD mode, which has less power loss than 4WD mode.
One limit is that the injectors can not inject during combustion and exhaust strokes, so the injection window is cut in half. Also the high pressure fuel pump needs to produce around 2000 to 3000 psi of fuel pressure which is hard on the pump. It's not easy to find an upgraded HPFP either.
Old Mar 9, 2015 | 03:22 PM
  #2913
R/TErnie's Avatar
Like dave said the injection window is not 720 crank angle, but it isn't 360 either... We can sometimes inject up to 410 degrees. VW/Audi stuff injects between 100bar and 200bar rail pressure. Large injectors are scarce and the ones Bosch will make for you are very expensive. APR makes high pressure fuel pump upgrades (fixed displacement pumps) we increase the piston diameter and use the factory fuel lobe (lift) You can also add more lift or lobes to the cam profile that drives the HPFP. So you have the pump that limits you based on engine speed (since it's driven off the camshaft) and you have an injector limit based on window (crank angle) and engine speed (mS).
Old Mar 11, 2015 | 10:24 AM
  #2914
CBRD's Avatar
Headed to the dyno
Old Mar 11, 2015 | 12:22 PM
  #2915
nemsin's Avatar
Originally Posted by CBRD
Headed to the dyno
Is the pic working for anyone else?
Old Mar 11, 2015 | 12:41 PM
  #2916
mrfred's Avatar
Headed to the dyno
Wrong kind of Evo.
Old Mar 11, 2015 | 03:35 PM
  #2917
dr_latino999's Avatar
Veteran: Army
Originally Posted by mrfred
Wrong kind of Evo.
Thought process here -
  1. Yes, ready for testing!
  2. Wait, that radiator is pretty dark
  3. Damn it that's a firewall
  4. I'll take what I can get lol
Old Mar 11, 2015 | 03:59 PM
  #2918
CBRD's Avatar
LOL evo 8/9 pics coming next- evo x kit- here - again
cb
Old Mar 12, 2015 | 04:29 AM
  #2919
Benja's Avatar
Looks tops Chad.
What size?
Old Mar 12, 2015 | 01:16 PM
  #2920
CBRD's Avatar
This one is 7163- can also use slightly smaller in the same location-
more pics coming-
cb
Old Mar 25, 2015 | 08:19 PM
  #2921
555R's Avatar
Airwerks 83/75 vs EFR 83/74
Has anyone done any comparisons betweens these two turbos yet. Side by side testing for spool boost hp tq etc?
I'm currently running an Airwerks 83/75 and considering the EFR 83/74 or possibly the EFR 76/70.
Just trying to get a few ideas for the next turbo.
Old Apr 16, 2015 | 04:51 PM
  #2922
Veteran: Army
cb
Any progress for 8/9 testing?
Old Apr 16, 2015 | 09:45 PM
  #2923
awhit17's Avatar
Well the airwerks is a big journal bearing turbo with an inconel turbine and the EFR is a ceramic ball bearing turbo with a gamma-ti wheel and probably some turbine aero designed with response in mind....so you can extrapolate that at the least the EFR is going to feel a lot more responsive
Old Apr 21, 2015 | 11:27 PM
  #2924
555R's Avatar
well i spoke to my friend who shall remain unnamed mentioned the EFR 83/74 spools like a GT30 but pushes too much air causing surging issues in a 2.0 liter. and said the 76/70 would be a better size for the 2.0L. not that the 83/74 won't work but may have issues like that.
Old Apr 22, 2015 | 08:03 AM
  #2925
CBRD's Avatar
I am loving the 7163 Open Scroll stuff we are doing-
all of the cars are making 400+whp on our dyno on 93 with bolt ons- (some with stock airboxes and piping)-
we are testing smaller 6758 stuff- which should be interesting (also running two on our GTR)-
cb
Quick Reply: New BW EFR Turbo Thread
