New BW EFR Turbo Thread
#3545
#3546
then please let me know how clocking it differently would change anything when the actuator is positioned at a fixed angle???? Without changing the mounting plate there is no way in hell the actuator will sit at a different angle..
#3547
There are some pics in the "Technical Training Guide" and I don't see this at 90 degrees in the fully assembled pics, only in the "wastegate system" pic. I'm looking and reading on pages 26, 27, 57, 81, 82, 83.
They talk about "Lever arm kinematics" on page 26, but incredibly they don't show a dimension drawing of the parts in the desired positions at the extremes of travel.
#3548
clocking is done at the turbine housing . so there are infinite angles to be achieved. its not rocket science. 100% arm holding is available when the flapper arm and waste gate rod are at 90 degrees. but that 90 degrees is only available in exactly one spot for the turbine housing. the poster said the housing cant be at the 90 degree spot because the wastegate actuator can would be hitting block in that position. so the housing had to be clocked away from the ideal 90 degree angle.
#3549
On the plate I got with my efr the angle is wrong IMHO + it positions the actuator in such a way that it interferes with the block using the manifold I designed. To solve this I will make another mounting plate + use a longer actuator..
Just for the sake of argument here is the turbo clocked "right".... and you can clearly see how the supplied mounting plate doesnt work..
#3550
As 94AWD suggested, it is interesting to contemplate the optimal angle the WGA rod makes with the flapper lever arm. Greatest leverage is achieved at a 90 degree angle, so the question is what should be the spread of angles as the flapper moves through its travel. If the angle is 90 deg in the closed position, then as the valve opens, the WGA will have lower and lower leverage. Best overall boost control might be achieved for having the rod at 90 deg when the flapper is at 50% of its travel. Not sure if such a position for the WGA is possible though.
Are you planning to run a Turbosmart WGA? They are supposed to be needed for highest boost holding capacity. And I believe they now have a model that can pressurize both sides of the diaphram to allow for a wider range of boost control.
#3551
Anyway, we will know when it runs, shaft speed and backpressure will tell..
#3552
I would just put current plate in a vise and bent it to correct angle. but looking at my efr turbo here it looks like you have the incorrect bracket mine is nearly parallel to comp cover. also if you want better holding power on the arm the flapper arm should be made longer. they suck at holding steady boost at high back pressures. I would suggest 10-15% longer than stock.
#3555
Tuned one of the new FullRace 7163 low mount IWG kits earlier in the week.
Very impressed with spool and transient!
Setup was:
Stock block/stock cams Evo 9,
Magnus V5 plenum,
Boomba 70mm t/b,
HKS cooler
STM 3inch SD intake with bellmouth filter.
98RON fuel (~92MON)
Car still an ongoing operation atm as there are boost control issues, however on the street, starting at 2500rpm, I am seeing gate pressure (~14psi) by ~3300rpm in 3rd.
Setup was:
Magnus V5 plenum,
Boomba 70mm t/b,
HKS cooler
98RON fuel (~92MON)
