New BW EFR Turbo Thread
#3646
Speaking of new BW features, are those quick spool valve housings they showed at last year's SEMA available yet?
#3649
#3650
Boost Resource EFR Bolt-on Turbo Mitsubishi EVO X
just found this company making bolt on exhaust housings for the evo x platform. maybe they will work well. maybe they will follow with 8/9 version.
#3651
Should be out in late 2016. Borg has been really good on their promised deadlines lately.
#3653
Basically we are manufacturing our own 347 stainless steel investment cast turbine housing that will allow BorgWarner Super-Cores to bolt up to the stock location.
We are a small business but are doing big things in a small place.
Yes, what you see is our 3D printed prototype. We are currently waiting on the turbine housings to return from the foundry. It's a 90 day process between tooling, producing/machining samples, validation of samples, casting/surfacing/machining production pieces, etc. We will test both the 70mm and 74mm versions with independent 3rd parties and data will be released soon after.
#3654
We currently don't sell any earlier generation EVO products but might consider it with enough expressed interest.
What I would love to see is more A/R options for standard flange configurations for some of the EFR turbos. In particular, I'd like to see a T4 TS 0.9-0.95 A/R for the 7163. Or even more cool would be the same A/R but with the Garret TS V-band flange. Either of course have universal value.
#3655
the aluminum housing weighs less.. steel is more durable. I choose steel, unless is really racecar build
#3656
here is what we cooked up in twin scroll for the EVO X guys (sorry evo 8/9 guys nothing in the works yet for a TS kit for you sadly)...
we are in the middle of back to back testing against the 7163 open scroll Vband IWG kit we've been building a TON of- 12 on order right now- and 3 of the Twinscroll kits already on order- without even putting results up yet... phew...
#3658
#3660
