New BW EFR Turbo Thread
alpinaturbo (Jun 14, 2016)
#4052
as I said... results will tell, dont want to bang my own drum beforehand..
we will log turbo speed and exhaust manifold pressure and see.
#4053
I have 2.3 with the hks7460. Love the set up but can't wait to get my new cbrd efr7163 kit.
#4054
My downpipe material came in to Origin Fabrication today....let the fun begin
The mandrel clears the A/C compressor with ease too.
Untitled by Alex Whitacre, on Flickr
#4057
Awhite17,
Some advice from another person who has swaintech'd their manifold...
The exhaust manifold studs go into the oil galley on the cylinder head. When the head gets hot it wicks the oil from the galley, by the threads, and then onto the manifold.... which will cause it to stain your manifold.
I would recommend sealing your exhaust manifold studs to prevent this. Thread sealant or light thread locker.
#4058
Awhite17,
#4059
Also for anyone following, my 7163 and Full-Race manifold does not clear a Koyo Rad I bought, nor will it fit my FAL 12" slim puller.
I will be having Origin make me a slim radiator to suit, I imagine a CBRD one would work as well.
#4060
^ Not surprised, doesnt FullRace specify use of an OEM radiator with that manifold? Ditched my Koyo SpecR (54mm) for an ARC unit (29mm) to get my stuff to fit, even then its a tight squeeze. Can probably gain another ~15mm by offsetting the radiator mounts
#4061
Does the turbo itself interfere, or the manifold? I'm curious because I've got a Koyo, but it's the half rad.
#4062
AFAIK Full Race manifold doesnt work with E7/8/9 rad but needs a E6 rad..
#4063
^ apologies, you are correct - Evo 6 rad required: http://www.full-race.com/store/efr-t...anifold-1.html
FWIW the CP9A & CT9A radiators share the exact same dimensions (I've measured both), sounds like its more the depth i.e. thickness of the radiator that was causing the clearance issue rather than the position of the outlet
#4064
FWIW it appears that the full race manifold will not clear the top rad hose when using evo 9 rad... E6 rad has the top outlet positioned differently... I know that my first prototype also did not clear the top hose, so we redesigned it to clear.. just.. haah
#4065
I think you could get it to fit if you had a hard 90* elbow welded onto the exit instead of the Wiggins outlet I have, but it would still be darn close with a thicker rad. My Koyo is their newer "V" core which is 50mm.
My 12" FAL puller was hitting its shroud against the compressor housing of the 7163, but I think if you used a SPAL puller without the bulky shroud it would fit. No chance a factory fan will fit.
I'm going to have Origin make me a 1" (25mm) rad which will alleviate the issues with both the compressor outlet and fan shroud.
