New BW EFR Turbo Thread
#856
Big thanks to my sponser Robispec and now here is a twincsroll 7670 graph. Highlights:
637HP 588TQ @ 30lbs on E85 - response is sick.. spool is sick.. etc...etc.. couldn't be happier
And thanks to RRE!
Details:
05 evo RS:
BR2.3 RPM motor
HKS 280 cams
Twinscroll 7670 - Full Race manifold
one word: SICK!!!
And thanks to RRE!
Details:
05 evo RS:
BR2.3 RPM motor
HKS 280 cams
one word: SICK!!!
Awesome thanks for the info, I'm sure Ernie will chime in with some info. I'm just trying to figure out if I can hit 25psi by 3500 on my big 2.7 on pump gas, I will be using the smaller TS housing with the internal gate so the smaller a/r may help some as well. Also are you running just a 3" exhaust or something bigger?
#860
the high pressure actuator starts around 18/19psi with 2mm preload (minimum amount). It can go up to 32/33psi with electronic boost control set to full spill. For increased boost levels OR for more control, we are just about to release a dual-port internal wastegate actuator that behaves similarly to an external gate "push/pull"
the BOV is tested thoroughly by BW. Ill ask for permission to post detail
#862
Does that mean with the wastegate control line disconnected, it will only hold a maximum of 32/33psi? (just to make it clear)
What kind of numbers do you get with the "medium" wastegate? 11-12psi at 2mm preload with a max of about 23-24? If this is the case, if there any way to make it hold higher boost? External spring maybe?
Cheers, Mike
#863
Manifold for IW Turbos
I missed the info on how are evo owners going to fit the internal-wg EFR on the cars, more so the twinscroll ones.
I remember you were considering a top-mount manifold, what's the option at the moment?
#864
The way to make it hold higher boost is to replace it with the High Boost canister (just stamped steel and a spring approx. $56) or one of our dual port push/pull actuators (billet alu with a piston, seal, and multiple springs $160)
edit: ill work on updating our website over the next two weeks so everyone has a better understanding on this
#865
#868
#870
