New BW EFR Turbo Thread
#1262
Have all the comparative HP/TQ curves been taken in the same gear..?
To me, this is where I see a discrepancy...
The 7670 HP/TQ plots just seem too early for me to, like it was recorded in a much higher gear...say 5th...while all the others turbos were done in say 3rd gear!
*Edit*
And I'm aware the dyno sheets say 3rd gear...
*Edit*
#1263
The point of eddy current dyno comparison is that, if with the previous turbo I have used a an amount X of eddy current load, and now I have a turbo that makes a lot more torque and power, so I must use an amount of load of X+20% to have the same ramp rate, the spool curve can't be compared.
However this is an absolute GREAT result
#1264
*Edit*
*Edit*
Test was done by selecting 3000rpm as the starting point then loading up the engine and waiting 3 seconds to start the run,
The EFR just wants to make boost its awesome and I just cant see how to fake a boost log and the dd dyno is run in shoot out mode.
Mark
#1265
Same gear is used in all tests and its 3rd gear,
Mark
Mark
Looking at your whp dyno plot...it shows 2.5bar boost pre-3500rpm!!!
Relative pressure..? Damn!!!
That's no lag Mark!
#1266
This is how I would expect most to start a power run and theres no point starting it at anything less than full throttle its only the starting point to be diff,
The EFR is awesome on that set up.
Mark
#1267
We lock the dyno to hold 3k and then apply full throttle holding it there for 3 seconds and then let it run the power run,
Mark
Mark
But, I don't see the point in locking the motor to one speed and building so much boost...
Doing this for testing purposes is one thing, but it doesn't really simulate how the turbo will perform/behave on the track or street!
Yes, it obviously has the potential to spool quick and likes boost, but were all the other comparative turbos listed on your dyno sheet also tested in the same manner..?
#1268
I hear you about loading the motor with the dyno...
Its my standard method of testing so yes they are all the same,
On the track you are never at 3k so that doesnt inc in the RR test and on the street you are cruising and then press the accel pedal is the same.
Mark
#1269
The difference between the 3 curves at anything less than 5000 rpm is ridiculous. I have to say that when I looked at the curves, I thought for sure that the EFR was run as you say, but the other 2 were run up from a light throttle cruise. This because the other 2 are shown making less than 180 whp at 4000 rpm, which I figure those turbos are capable of without the 3 second WOT preload. Have to wonder what the 3 curves would look like if each run was started from a 3000 rpm light-throttle cruise condition (like street driving). Great results though - thanks for posting!
#1272
They were all run in the same way 100%, The GT30 was about a year ago and the S200 was about 6 months.
Mark
#1273
That is NOT the correct way to run a DD. You are in effect building boost PRIOR to throwing the switch for the power run to commence (ramp up) hence the amazing amount of boost at the start of the "logged" run.
The correct way to start a power run (shoot44) on DD (Dyno Dynamics) is to run the car upto 2000rpm, flick the switch to start the ramp rate and power run and then floor it then the the boost from start to finish would be logged i.e it might actually show some spool up.
#1274
Mark
Mark
The run can and should be started as soon as 100% throttle is applied.
#1275
The other 2 turbos are only showing 1.3bar between 4000-4250rpm...or there abouts!
By you saying all turbos were tested in the same manner @ 3000rpm, you are basically implying that the GT30 and S200 built-up virtually zero boost under load...
