Passenger side axle stuck on output shaft???
So I'm in the process of dropping my trans and transfer case. The passenger side axle sure needed alot more oomph to get it out. And when it did come out, it came out with the output shaft. And of course, being so long, I cannot get it out, because the last boot is hitting the oil pump housing. Has anyone had this happen? I'm hoping the splines arent twisted together etc. Has anyone had this happen before? Trying to figure out where to go from here.
I got them separated no problem. What a pain to get out though. I bent the last metal part of the axel (one between the green part and transfer case) just a little bit. I sort of banged it back into shape, but wondered how this would affect anything? I know the rubber seal goes into this part, but wondered if I need to get a new axle now???
MitsuJoe
468
Feb 20, 2016 11:17 AM
