help oil light stays on!!!
Dude, stop driving the car... I am telling you, you will suffer more if you continue to drive it, until you find out 100% its the sensor, I can show you the proof. My motor is still apart, now into it a few grand and I am not done yet and I am doing all the work myself.. I had the same symptoms.
well thats the thing i had no other choice but to drive it, i had a meeting at work i could not miss. So far what ive read up is that it could be a bad sensor, fuel pump, or spun bearing. I think i can eliminate the spun bearing as my motor doesnt sound like any of the knocking, cluncking, or ticking ive heard on youtube on spun bearings. Im leaning towards a bad sensor or the fuel pump. Either wat im taking it to AWD motorsports tomorrow to get it checked out.
WHAT "FUEL PUMP"? You mean OIL PUMP I hope!!!
yes sorry i mean oil pump, had a bad day at work then all this crap with the car happens. Yeah i parked it for good, what was the cause of your failure? low oil? bad oil pump? Im completely stumped at this crap.
ok update, i finally found the damn sensor on the block after countless hours of looking. Now i have a quick question, it appears to me that the sensor is leaking because when i put my finger around it i get a collection of oil on my fingers. Should i put some type of sealant around the new sensor to fix this leaking?
ok well update i switched the sensor out and as soon as i fired up the car the light was off!!!! left it running for 5 min and then took a 10 min drive and no light is on. Thank you everyone for all your input.
Registered User
just saw this thread yea bro its a sensor behind the block kinda hard to get to but it went away after i replaced mine. i did a search on here and found a couple of threads on it which helped me out had a couple of pics on it to but glad you took care of it!
