Car will crank but no Start
So when i crank the car it fires, and did a log is goes up to 600 rpm but then stall out instantly.
Sometimes it starts, When the motor warms up, i starts right up always. Thats the weird part
Things i checked.
-Spark plugs
-timing
-loose wires
-fuel pump
-compression is good
- Cam angle sensor
The only thing i can think it might be that i havnt checked is Crank angle sensor
Things i checked.
-Spark plugs
-timing
-loose wires
-fuel pump
- Cam angle sensor
It may be just a cold start problem. I was having the same problem till I reflashed the car. I'll go check exactly what I changed to get my car to start. It use to take me 15min to start my car and starter fluid till I figured out how to fix it I'm on E85 so my car is a bit different than yours.
I had to go into main map fuel settings in the ECU and change my Injector Cranking Enrichment IPW.
-0* - 108.1ms
18* - 83.1ms
45* - 58.1ms
68* - 48.6ms
As your coolant temp increases your cranking ms should decrease gradually.
That seemed to fix my car. Not sure if it will help you out or not.
Mikey
-0* - 108.1ms
18* - 83.1ms
45* - 58.1ms
68* - 48.6ms
Mikey
-0* - 108.1ms
18* - 83.1ms
45* - 58.1ms
68* - 48.6ms
Mikey
-0* - 108.1ms
18* - 83.1ms
45* - 58.1ms
68* - 48.6ms
Mikey
is the n xml i can add from somewhere
i'd maybe check the iac valve. had the same problem but it was consistent to a low idle when i started. it died to if i didn't gas it. just pull it out and check it. make sure that it is still in one piece. when i took off my old one, the whole top half was gone. all the plastic was pretty much gone. good luck.
wazzelby
Mar 29, 2017 06:28 AM
