should i go FP Black on my Buschur Build 2.0?
Old Jan 21, 2011, 01:38 PM
bnr34rb26dett's Avatar
Wink should i go FP Black on my Buschur Build 2.0?
I own a Evo8 with 9 turbo on there right now
so here is the engine mod list so far
Fully Built Buschur 2.0
Buschur Stage 3 Head
Bushwhacker transmission with exedy twin plate
Crower Rods
Je Pistons
Arp Headstuds / Main studs
Buschur BF 272 Cams
Buschur inline MBC
Buschur Short Ram intake
PTE 1000cc Injectors
NGK BPR8ES spark plugs
Walbro 255 Fuel Pump
Buschur Street Core FMIC
Buschur LICP
Buschur UICP with Tial Flange and 1g DV
Buschur Mini Battery
Buschur 65MM Ported Throttle Body
Buschur Ported Intake Manifold
AWD Motorsports Billet Motor Mount Kit
Evo 9 Turbo
Perrin O2 simulator
HKS DP
Test Pipe
ETS Exhaust
im looking for around 500+ AWHP and i figured FP Black will suit my need
what do you guys think? are there any other turbos out there that will be more reliable/ spool faster than what im looking for? would i be happy with a fp red?
if i buy the FP BLACK turbo, what else do i need? i need new oil feed line right? new BOV? anything else? its already got 9 turbo on there so im assuming that i wont need the evo8->9 converter.
would i need any other supporting mods for a bigger turbo?
any comments/ suggestions would be appreciated!
thanks
Old Jan 21, 2011, 01:47 PM
raasfaas's Avatar
That's a pretty good looking list of mods there. I would say that for your goal of 500+ (on pump gas I assume) imo the black would be your best bet if you're sticking with the stock frames. You're going to have to push the red much harder to achieve that vs the black.
Since you have the 9 turbo now, no you don't need the install kit, but you're definitely going to need the oil line kit. You may want to consider a better bov too, based on what I've seen Tial and Synapse seem to be the more popular ones.
The only other mod that I would think to compliment your list is an ign system. Other than that you should be able to hit 500+ relatively easy with the Black.
Old Jan 21, 2011, 01:57 PM
raasfaas's Avatar
I would say since you have the ported int and tb, you would benefit from a ported exh manifold also.
Old Jan 21, 2011, 02:16 PM
thanks for the quick response.
yea i forgot to mention that i do want to go stock frame turbo on pump gas
so so far i would need
fp black
oil line kit
ported/aftermarket ex mani
Tial bov
any other supporting mods or recommended turbos anyone?
Old Jan 21, 2011, 03:03 PM
arnoldp's Avatar
I would get the buschur double pumper just to be safe. I think 500hp is pushing the 255 a little beyond its limits. Thats just me though. The build looks pretty sweet man keep up the good work
Old Jan 21, 2011, 03:43 PM
keath's Avatar
Well i did not mAke 500 with my br2.0 fp black on 91oct
Did make almost 600 on e85.. Way i see it dyno is just number but i could guarantee u thAt ur setup will be fast with black
Old Jan 21, 2011, 04:50 PM
EVO8LTW's Avatar
How do you have a 1G DV with a Tial flange?
I made 460ish on the BR dyno on 93 with an FP Red and similar mods to you. That was with a 1G BOV and a single pump too. I later put on an FP Black and made 520 something (Dynojet sim) on Virtual Dyno, also with the 1G DV and a single pump.
I just pulled off the Black to go autocrossing...
Old Jan 22, 2011, 12:39 PM
so possible double pumper...
r there any other turbos i should consider??
Old Jan 22, 2011, 01:18 PM
Pure EvoIX's Avatar
Instead of the double pumper, how about the Aeromotive 340lph Fuelpump or the deatschwerks dw300 fuel pump. Should provide enough fuel pressure for 500whp.
Old Jan 22, 2011, 02:57 PM
would i need bigger injectors or just pump?
Old Jan 22, 2011, 03:10 PM
Pure EvoIX's Avatar
If running straight 91, i think your 1000cc is enough. If you want to be safe just upgrade to 1200cc and sell off your 1000cc. If you are going to do E85 in the future, 14500cc should be enough.
Old Jan 22, 2011, 04:15 PM
38six's Avatar
FP Black is nice but the HTA 86/ 6262 would be better.
Old Jan 22, 2011, 09:14 PM
StreetThisEvo's Avatar
FP Black and a BR 2.0 is a killer combo! Worked great for me.
Old Jan 23, 2011, 01:57 AM
evo4nr's Avatar
I'd go 30hta or 3076gtx.
Old Jan 23, 2011, 09:24 PM
Wink Is there any particular Exhaust Manifold thats ideal for FP Black??
so the title pretty much says it all. i will be getting fp black soon and im thinking about getting rid of my rusty stock manifold.
what exhaust manifold are people running with their fp blacks?
are there any particular ones?
Quick Reply: should i go FP Black on my Buschur Build 2.0?
