Wazmunstr - My transmission rebuild thread
#31
i just read this, did he not preload the output shaft with shims? output shaft and Center diff are preloaded with shims you have to use solder and crush it measure it and use the right shim for the preload, the input shaft has end play. i also drilled a couple holes in my shafts for extra oiling to a couple bearings.
Take a look at my thread about transmission rebuild, you can see what worn parts look like.
Standard value:
Input shaft end play: 0.05 − 0.17 mm (0.0020 − 0.0067 inch)
Output shaft preload: 0.13 − 0.18 mm (0.0051 − 0.0071 inch)
Center differential case preload: 0.05 − 0.11 mm (0.0020 − 0.0043 inch)
Standard value:
#32
i stayed right at the tolerences, i have had only one problem shifting and thats 1st was tuff when it was Really cold out [oil issue, or clutch adjustment] once warm it was butter, after rebuild my center diff went out [1.5k miles] due to Tcase issues [bad ACD clutches?,BAD Pinion&ring], shaft spun HARD in the center diff and jacked it up so bad it dont hold the shaft properly now and it leaks output tube is also cracked, NEW Tcase and quaife center diff being installed soon after my thumb heals.
#33
#36
Hey guys, OP here. I never check tolerances, since I was only replacing the input shaft bearing. I simply removed the "extra" shim that was causing the input shaft to not move at all. after removing that shim, it moved freely without any play. It's been two years and 27k miles since I created that post and it's still running strong. notchy as hell, and it grinds sometimes from first to second at low rpm's when shifting fast. autox, high rpm shifts, no grinds ever.
wazmunstr
149
Oct 9, 2019 02:21 PM
wazmunstr
10
Feb 6, 2016 01:05 PM
wazmunstr
23
Jan 30, 2011 06:23 PM
