HKS 272 cams
This is were you have to draw a line. 1) chose to keep the stock valve springs or 2) upgrade. The problem is, all the cams that work with stock valve springs are not made to make much more than 20-25whp over stock cams. Setup depending of course. Personally I think the S1s are much better than the HKS cams. Also the S1 and S2 spool the same but the S2s make about 25whp over the S1. The only problem is you need valve springs to run S2s. I recommend S2 w/ valve springs to everyone because you will never have to change your setup again. Those cams are good to 700+whp. The problem with S1s is, if you upgrade to a larger turbo in the future they will hold you back and you will have to get new cams. I don't know about you but I would rather buy one set and never have to worry about cams again
Mikey
* Edit - I wrote all that just for you just for you to say never mind?
Mikey
All I have done now is wb255, full 3 inch exhaust, hard pipes, and a tune.
But for spring I was going to upgrade to 750 injectors, 10.5 turbo, cams?, and a new tune.
What would YOU think would be the best bet for a intake and exhaust cam.
I dont plan on going any higher then this. (my wife told me)
Only car I am going after is a LS1 vett that a mod on my local mitsu forum has.
I apologise, I felt that I should have done more research on this, but you did end up helping me out a lot more with this post.
Mikey
I have these cams in my car and I'm happy with them, I when from 304whp/295wtq to
341whp/319wtq stock turbo (10.5) and bolt ons @ 23psi they are really good for a daily driver \
I'm goin to swap them for the new HKS 274/278 but that's because they came with my new turbo.
Thanks everyone! I think after seeing this I'm just going to save up for a better set of cams for the future. I'd rather pay for a re-tune once and have a more solid set of cams in, rather than having to get multiple re-tunes if i changed my mind on the cams in the near future.
GSC's hopefully by spring
Mikey
Correcto. OP I understand that HKS cams are cheap and a steal. But they are the second worst cam for your car. I had an HKS 272/280 combo and LOVED them. Idle was great, power was good, got to keep stock valvetrain so that's a plus and the list goes on. Until I got my new GSC cam and have the same added benefits of a cam twice the size and idle that's better... HKS are old design cams and are okay for 250.00. I have HKS cams in my room I'll sell for 50.00 just to get them out of my house.
Here is what a back to back did HKS to GSC cams. Same boost and timing!
Mikey
Mikey
moevo9
42
Oct 26, 2012 01:58 PM
xpehbam
25
Oct 14, 2009 07:21 PM
Gary@MellonRacing
11
May 7, 2009 11:41 AM
