Reflective Gold Heat Barrier Foil
So i am going to be placing a order for some Reflective Gold Heat Barrier Foil and i was contemplating re-lining my hood liner with the foil. Do you guys think it will help with under hood temps?
here is a example picture.... i know its not a evo
The foil on that car is to keep the exhaust from melting the Hood.
All your going to do with your hood is keep the Hood from getting hot. But it would be more pleasing to the eye.
Try the Foil on something you dont want to get hot...front side of valve cover or Upper Intercooler Pipe... My fav...Cam Sensor from evil Tubular manifolds.
So if I understand you correctly, you want to put a heat shield/barrier between your engine and the rest of the world? Why would you want to reflect heat back down into the engine bay?
I can understand wrapping the upper intercooler piping or lining the side of the valve cover, but why the hood?
Now your post makes sense, you didnt mention that you were going to be wrapping a CF hood in the original post... If you got the coin for it do it it might have some benefit helping save the hood but with CF hoods the top is usually of most concern not the bottom unless you like the bling factor because it will keep the temps higher in the bay
The silver foil is substantially MORE reflective than the gold -- something like 96% reflective for silver vs. 7x% for gold.
Look for the thread by IndyEvo for technical details.
Earls Fittings in Indianapolis sells the silver by the foot. It's about $24.00 per foot (15 inches wide) last time I bought some.
IMPORTIMAGE
Lancer Vendor Classifieds
378
Jul 13, 2016 06:51 AM
Phoenix*
Jul 15, 2011 12:05 PM
CO_VR4
69
May 22, 2011 07:32 AM
Indy Evo
62
May 28, 2010 08:13 PM
