On-Boost Compressor Surge Issues
Synapse,
Here is a pic of my setup, 4'' dry filter (I believe!)
Ya iam hoping it would solve the issue. But the OP also brings up a great point and that is "Too much boost Too soon" so going with a bigger hotside, would slow this porcess, thus, avoiding the issue. so the hotside might not be a direct solution but it would work.
Yea, I suspected that as being part of the issue. The only reason I don't think I had issues earlier on was a boost leak I never knew about keeping it under check (EGR valve). Now that all my boost leaks are fixed, surge and spiking are my new friends. I know the spikes can be controlled by using electronic boost control, which I might do via a GM solenoid and the AEM, but the surge is in large a result of the tiny hotside.
Will be interested to see your results.
This may sound like a really stupid recommendation, but if it doesn't hurt anything . . . Any way you can jam that 3" tube further in to that reducer coupler and see if it helps your cause? Almost to the point of wrapping around the compressor inlet.
I have the same setup 35r/.63 with the same issues ur describing. I spoke to Tial about it, and from what they have seen is the smaller hotside is one of the factors played into surge.
It kinda makes sense since it doesnt seem right for the comperssor to push more air than what ur engine can process thru the smaller hotside. I will be swapping mine soon, so I will report back my findings.
Synapse,
lathiat
Sep 1, 2015 10:58 PM
AWDralliart09
16
Jun 2, 2012 03:43 PM
boonkae
Mar 2, 2012 07:12 PM
paulyd04
Apr 10, 2008 11:27 AM
