Octane Boosters
Octane Boosters
Well, with 94 being eliminated in NY, instead of getting reflashed for 93, Ive decided to run octane booster, and in cases where I can get race gas, well...race gas. lol
Ive tried an octane booster by Jetgo, and I must say, that was so far the best octane booster Ive used in terms of gas mileage. I was getting nearly 60 more miles to the tank easily. But that was the only time I used it since locally, I havent been able to find it.
So I have been using the yellow bottle of Turbo 108, and it seems like the car runs smooth, but on my last tank, the gas mileage was horrible. I just bought a bottle of NOS racing octane booster, and Ill see how that goes once I go to fill up.
I saw the OUTLAW octane booster, which either comes in the superconcentrated formula, or a package of 4 canisters that are 3.5 oz. It says that the canisters are concentrated enough that only one canister is needed, but Im skeptical.
I do realize that this isnt good for my cat, or 02 sensors, but I dont go overkill with these octane boosters. Just alittle mix with 93 to get the octane up a bit since my car is tuned for 94 gas.
So what are other experiences, etc etc.
TIA
Ken
TIA
Ken
I find it hard to believe that a 3.5 oz bottle of anything could raise the octane a point.
Toluene is 114 octane and Zylene is 117 octane.
If you do the math, it takes one gallon (128 oz) of Toluene to raise the octane to 94.5.
(13 gals of 93 = 1209 octane; 1 Gal of 114 =114 (1209+114=1323); 1323/14(gals)=94.5 octane
Those bottles of octane boost are B.S.!
That octane booster would have to be 4169 octane!!!
I've tried alot of the octane boosters out there. From my experience that Outlaw crap is crap. I started with 1 bottle, then 2, then 3... What a joke! I would have done better with some magic beans. I've also tried the NOS booster too and didn't get much results with that either. I did like the 104+ (black). I could definitely tell the difference with that. But I'm not sure how the long term usage affects the vehicle so I stopped. If there are any rocket scientists out there with your ears on, could you enlighten me?
Hey at least you can get 93oct. I'm stuck with 91 Feel my pain.
I would think using Toluene/Xylene would work best. I might need to start doing this soon too. Might move to Maryland, where they don't sell 93 on all the pumps.
i've been researching the "octane booster" too and toluene keeps coming up as the best bet. people say you can get it at the home depot for like $3/gallon. so, what do you guys think, a gallon of toluene per tank or is that too much? anybody heard from the rockert scientist yet? my problem here in southern ohio is that when buy 93 or 94 octane you usually aren't getting it. there is noticeable differences from fill up to fill up. any one else have this problem?
theres a unocal by me that sells 100 for 4.99 a gallon... 1/2tank with 91 1/2 tank with 100 averages 95.5...what a difference, in the pocketbook as well as the car....65 dollars to fill up.
Originally posted by WILDMAN
Hey at least you can get 93oct. I'm stuck with 91 Feel my pain. [/B]
Ya I feel your pain bro Im putting in 5 gallons of 76's cool blue 100 octane in my car every fill up and at $4.99 a gallon its not cheap
Registered User
I think the idea that higher octane gives you better power is BS. Unless you are tuning for the higher octane, or unless you were having knock sensor limiting prior to octane boost...the higher octane is just costing more. I used to think higher octane meant more explosive fuel. Then I did some reading and found out it is the opposite. Higher octane resists detonation and thus prevents knock at high pressures and temps. So if you are running higher boost, you need higher octane...or leaner, or hotter cylinder temps. Damn, I can't find my document that I downloaded about a year ago when I was trying to learn about all of this stuff. This is what I recall: There was no reason to buy higher octane fuel unless I was going to be pushing toward detonation. If the car is stock, it's tuned for 91 (?) octane and higher octane just spends more money on exactly the same amount of fuel. I have a degree in chemistry (bachelor's) so my reading wasn't totally ignorant...but I'm no hydrocarbon fuel expert and I only know what I know about tuning from reading the forums in here.
Registered User
Ok. Not the stuff I read a year ago (which was government documents) but states the same stuff, generally:
"There is ABSOLUTELY NO BENEFIT to using a higher octane than your engine needs. The only benefit is increased profits to the oil companies that have cleverly convinced some of the public that their new "Super-Duper, Premium-High-Test, Clean-Burning, Used-By-Famous-Racing-Types-All-Around-The-World, Extra-Detergent-Laden-Keep-Your-Pipes-Clean, Extra-High-Octane" fuel is your engines’ best friend. The swami is telling you the truth, don’t listen to that talking cartoon car.
The swami hears people insisting that they got better mileage, better acceleration, and less dental plaque by switching to a high-octane fuel. The swami reminds these people that in every pharmacy is a special miracle pill that is often prescribed by doctors, it works wonders because people believe that it works wonders; it’s called a "placebo". The swami warns: never confuse faith with physics!"
This comes from:
http://www.bajajusa.com/Who%20Needs%...ane%20Fuel.htm
This comes from:
