Best Ethanol Analyser for Closed Loop Feedback?
Old May 6, 2011 | 02:42 PM
VGergo's Avatar
With the Mr Fred Wideband control closed loop afr patch the front o2 sensor is free you can connect there the E85 analyzer . With an other patch what can manipulate the octance level we can richen up the fuel and lowering the timing if the ethanol content is not 85% . On pumg gas program we can switch to EGT sensor
Old May 6, 2011 | 03:44 PM
RSMike's Avatar
i'm pretty sure you would reduce the amount of fuel going into the engine as gasoline has a more energy per litre than ethanol.
can the stock ECU take a square wave input directly without going through the ECA?
Old May 6, 2011 | 05:51 PM
mrboost05's Avatar
Originally Posted by JDMevoBOOST
So basically the guy is wanting a true flex fuel, with the ecu adjusting for ethanol content. That has been in the works with tephra, but not sure how far he has got so far. I haven't heard of any other tuning solution that can do it yet.
there was a big pump gas thread in the dyno fourm that had good info about what the op is asking for ill try to find the link.
Old May 6, 2011 | 10:34 PM
Stealthmatt's Avatar
yep apparently hooking it into the digital input of the ecu - allows the ecu to read it like a voltage... so hopefully it works well
Then going to output the information to a racing dash as well
Old May 6, 2011 | 10:35 PM
that would be great
Old May 7, 2011 | 05:09 AM
VGergo's Avatar
My idea is only a safety function, the injector scaling and the tune in the ecu is for E85. If in the gas tank the e85 content is different than it can protect the engine.
Or on alt map, pump gas tune if the Egt is too high under heavy race also can protect.
Old May 12, 2011 | 08:12 PM
r34skyline's Avatar
hey guys,
just put a Link G4 in my R34 GTR, and have the gm ethanol sensor as well - i also bought one of the Zeitronix wiring harness for the content sensor, is this what i need to feed the digital input to the ECU? or do i need another plug/lead?
cheers
Old May 13, 2011 | 03:48 AM
RSMike's Avatar
heya, you can ask those questions on the G4 Forums at www.linkecu.com
but to answer your question, just put the signal wire to a digital input. No other boxes required.
Enjoy LinkEcu power!
It's good to see Aussies supporting NZ products
Old May 14, 2011 | 06:08 PM
mrboost05's Avatar
Originally Posted by Stealthmatt
that would be great
found it
https://www.evolutionm.net/forums/ev...p-pumpgas.html
edit that was not the thread i was looking for but still a good read ill come back and edit the links once i do find it.
CO_VR4
Oct 25, 2016 05:30 PM
jracer
Jun 15, 2016 05:08 PM
lostsoulsevo
Jan 8, 2016 06:45 PM
Chris@nolimitmotors
EvoX 'For Sale' Electronics / Lighting / Audio
187
Dec 11, 2015 08:34 AM
Duh Panda
35
May 11, 2012 09:07 PM
Quick Reply: Best Ethanol Analyser for Closed Loop Feedback?
