Valve Cover Rubber Washers
If you mean the gaskets under the valve cover around the spark plug holes, they come as part of a valve cover gasket set. If you install the valve cover without them the spark plug wells will fill with oil.
i'm sure he means the grommets that come attached to the bolts themselves... i've personally not had to deal with this issue... look at the gasket itself. if it covers the bolt holes or seperates them from the oil then youre fine. if they arent and the grommet is the seal then youre screwed... the pressure in that cover under boost is enormous so without some way to seal the bolt holes they will leak. best bet would be the dealer bro sorry...
Thanks
CBRD
118
Sep 21, 2009 09:58 AM
worksevo89
Jul 11, 2008 10:29 AM
EvoDan2004
27
Jun 5, 2008 06:16 AM
