Strange High Pitched sound
Hey everyone...I'm fairly new to evos. I have an IX mr which i purchased a couple of months ago. Just recently I started noticing a high pitched sound when i deccelerate both in and out of gear. It only happens at very very low speeds. So i will decellerate down to about 10 or 15 mph and it sounds like a high pitched whistle until the engine gets down to idle. Also, the sound is very quiet...it is not a loud whine or anything. Just a very quiet, high pitch whistle. Any input on this would be much appreciated. Just a little bit worried hear as I am new to my evo and don't want to see anything go wrong just yet .
Also, I have a few basic bolt ons....hks bov..upper and lower IC piping...TBE...intake...radiator...and CBRD protune.
Thanks!
Thanks!
It only happens in 1st or 2nd gear, correct? Those two gears are VERY loud on evo's, I believe they might be straight cut instead of helical? Mine, as well all 3 other evos I've ridden in, do this.
If you get a whine at high speeds (highway) though, check out your transfer case. Good luck
EVO8GSR
11
Mar 9, 2006 09:18 PM
