Upgrading Coils and Ignition control
Has anyone attempted to upgrade the coil packs and installing an MSD (2-DIS?) box?
I have always used MSD boxes on my american cars, but was curious if it was as easy to do on the Evo, and if its a worthy upgrade? It seems to me that nobody has addressed ignition other than adjusting the timing, using colder plugs, and upgrading spark wires.
I've seen that too.. I am more curious is if its an effective mod for this car, or a waste of money.. I built a fuel injected v8 for a friend, and used an MSD Digital setup with 4 coils..
I am not too familiar with our ignition system and whether it will do a multiple spark discharge. I've also heard using some aftermarket ECU upgrades could burn up the stock coils..
Thanks.. I was wondering if the MSD SC series was worthwhile, partly because it has a rev limiter and shift light capability too, but also because it can prevent plug fouling and fire through fould plugs (In my past experience)
I love integrated solutions, but I've been wondering if this would help the periodic misfiring I get.
Originally posted by chiraoka
What about this ..... some people have reported good results but personally I have not tried it yet
Carlos H.
Carlos H.
Shiv
The MSD DIS-2 can't be used on the EVO. I know this because we tried and it burnt out the transistor inside the coils. It is made for a car that has external transistors.
Now we have to buy new coils which are not cheap.
You Evo guys are learning the lessons we Lancer guys learned about the Mitsu DIS system almost two years ago. You can see the failed results of the test fitment of the MSD DIS if you a search or two. Does nobody know if the HKS DLI-II for the 4G64 powered Eclipses works or not? I can't imagine the setup being different enough to warrant a new box like mentioned earlier.
I run the IV/V/VI DLi on the VII .. you just need to modify a pin .. that's all .. just 5 minutes and it's plug and play after that ..
Thats the most encouraging post I've heard so far. Like everyone's experience from trying it.. I had the concern about burning up the coils. I hear alot from import sites that say "Ignition amplifiers are not needed" but I find it hard to believe that anyone wouldn't want to use something that can get the plugs to fire in nearly any condition, especially when your dealing with high boost and the potential to get a misfire or spark quench. Do you have a pic of your DLI unit and the connector? Also are you using it with the stock coils, or had you replaced them?
The MSD DIS2 will absolutely not work on the EVO's. They are definately intended for vehicles running external power transistors. We've had some ignition issues with the car and I have built a full CDI coil on plug ignition system for our car. It's not going to be the cheapest solution, but it will be the best. I'm finishing up the wiring details that will make it a complete plug in assembly (no cutting or splicing of your factory harness). Right now I'm trying to determine the power level I want to run the systems at. To date, I've run the system with .050 plug gaps at WOT under 21psi with no misfires. This system is a full CDI (rather than inductive) igntion and features multi-strike capability. I'm working on the final system mounting and wiring details as mentioned previously... but I thought I'd let you all know what I was up to.
I'll post a pic of the ignition in our EVO development section shortly, just to give everyone an idea of the system's quality.
http://www.buschurracing.com/EVODEV1.html
Take care all.
Take care all.
