Bullseye s259et
Bullseye s259et
What are your guys opinions on this snail? My friend has one that he had on his cobalt and is parting the car out and brought the idea up to me about using it. It has a t3/t4 flange. I was wondering if anyone has used it on their evo or not. Let me know what you think. Would I have to build the motor to run this turbo or could I run it on stock block for a while?
Thanks
Thanks
I've had good luck using Bullseye turbos.
One thing i would recommend is that you feed oil to it from the oil filter housing and not the cylinder head. These turbos require considerably more oil than a ball-bearing unit, and sometimes the head just doesn't provide enough volume or pressure.
FS[Mid-Atlantic]: Carbonetics triple disc clutch
Technical10
Dec 10, 2014 05:26 AM
Tractionlimit
Jul 10, 2009 11:00 AM
