What route to go?
tactrix cable 1.3u and evoscan.. if you need them pm me i have them in stock and im located in US.
if you want to do this with 93oct you need a larger turbo for sure, unless you use methanol injection, then it can be done.
my customer with e85 and fp green hta at 30psi with stock block and head with gsc s1 with 11 flat afr went 11.9 @ 120 last week so theres an example. the ET is crappy of course but the MPH shows what its capable of. that is just intake, exhaust, cams, ecu boost, fmic, and supporting fuel.. nothing crazy.. i wanna say it was around 470whp due to the rich AFR.
evos respond very well to mods.. that is at least on your side, and they hold up pretty well with high HP on stock block as long as the torque is well controlled.
