Is this "Serious"?
Is this "Serious"?
Hi,
will it be a very serious problem when there is sign of oil leak at the engine top gasket area below the intake manifold?
The ride was just rebuilt 6 months ago and now notice oil stains along the top gasket area...
Will it effect the engine compression and performance?
My car just dont sound furious as it used to be...
What should i do?
What should i do?
The more descriptive you are the better results we can give. Could be head gasket from doing head studs with head still on but seems like the engine was rebuilt and figured that would have been done while it was apart. You need to list your mods, are you all stock or running more boost? I started getting a misfire randomly under high load and it would come and go, took a spark plug out and saw a puddle of oil on top of the piston. Took the engine apart for other reasons and saw oil pouring out of the intake port and the one cylinder was coated with oil. It's from running more boost and having the work I have done but mainly from not having an oil catch can in the intake which will benefit even a stock engine and mine is 6k miles fresh. Could be as simple as a bad pcv valve, and the oil is leaking out of the intake gasket, the stock pcv valves supposedly suck from day one. I just got some Saikou Michi catch cans and a krank vent (inline pcv valve) to fix my issue. You might be having the same issue or could be from the head gasket, or could be from the valve cover gasket. Instead of guessing, clean it off with brake cleaner or whatnot, get a DYE you put in the oil, drive it enough so it leaks, and use a special UV flashlight and the oil will glow and will show where its leaking from.
Will it be necessary to dismantle the head again?
2.0L
85.5 JE P
BC Rods
Oem Crank
Oem Turbo
Oem Head Gasket
Boosting 1.4 bars
I noticed that the oil is just below the intake and i believed is most likely its frm the head gasket...
What should i do now? Can i just ignore it or remove the head?
Thanks
I would get a set of the catch cans I mentioned (not the cheapy or non baffled type) even if it's not your problem it's still a very good part that only adds to the life of the motor.
To find out where it's coming from, do what I said with the dye....Mine was having the same thing, pretty sure it was the head and not the intake but my head gasket Lookedd perfect
Could seperate the intake mani from the head and look inside and see if its leaking from intake like mine or not.
Could try torqueing the head nuts down and see if they get any tighter or not, might help, might not
do like what the guys posted above, or since u said the engine was built 6 months ago, check and see what your warranty is with the shop that rebuilt it? which im assuming is what you did? or if you self installed the rebuilt engine do like what was posted above then report back...
good luck
good luck
real fast
Apr 15, 2016 05:28 PM
aka03
10
May 29, 2010 05:12 PM
