Is there a Plug & Play 2.3L Crankshaft for Evo?
Hi,
just wonder is there any pnp 2.3L crankshaft for evo 4~9 which we can maintain the oem rods lenght, 85.5mm piston and oem rods and crank bearings?
Just hope that there is 2.3L stroker crank for oem rods and pistons size (I mean not Mit Oem rods and pistons).
1) Let's say if i want to use the 4G64 crankshaft, what rod length and pistons size should i go for?
2) Is there any other crucial things i need to mod (engine block, over size bearings (rod & piston), water & oil ways, oil squitters, etc) for my 4G63 engine?
3) Can i maintain the balance shaft?
4) Can i use back my current crank sensor?
Thanks
Hi, yes you are right, im currently using a forged BC rods with oem rods length and 85.5mm JE pistons.
Thanks
Thanks
2. U will need over size bearings if the crank was turn. U need to tweak a litle the oil squitters for clearing the path of the piston.
3. Eliminate the balance shafts. (U can get the racing balance shaft for the oil pump from AMS)
4. U can use your current crank sensor.
Thanks
Thanks
2 - no, just need to clearance the block where needed (number 3 piston for me)
3 - yes, 4g64 is equipped with balance shafts from stock
4 - yes
thanks for sharing but im a bit confuse on the piston size as 6mm higher than stock but some said smaller piston? So, what does it mean? Sorry for the nob question...
Hi Mike, what do you mean clearance to the block on the no 3 piston?
Will my rods able to match the new 2.3L crank?
Hi Guys,
Wiseco: K596M855
(for 100mm Crank)
You cant use the stock 2L piston it has to be a Stroker Style Piston...
