High Revving Setup
Old Mar 25, 2011, 02:09 AM
Kins's Avatar
You may want to look at going for a LR2.0L rather than a regular 2.0L.... or maybe building a destrokered 4g64 short block.
Basically you want a strong light rotating assembly. Manley turbo tuff ibeams are pretty heavy too so you're not off to a great start. If you're building it for the strip I would opt for alloy rods. Steel for a street car. I would also stress the importance of fitting the best rod bolts you can get!
You'll have to ditch the air con (it won't last at those revs)
Fit a balance shaft removal kit
Fully dynamic balance your rotating assembly
Fit a Fluidampr crank pulley
Go for a fully worked head
Fit top quality valve gear
You'll need a turbo that flows over 65lb/min
I'm having a LR2.0L build done and hope to rev past 9K. If you're interested have a look here:
http://www.lancerregister.com/showth...ighlight=build
I'm concerned about oil pump failure and considering fitting a dry sump mainly because the OEM pump is likely to fail.
HTH and good luck.
Originally Posted by Babs
Exactly what consists a high revving build? Namely the block...
Keeping my block a 2.0L and I bought Manley TT rods, .020" over AMS/Ross pistons, new stock crankshaft, and Clevite 77 bearings and I wanted to know if I'd be able to hit at least 10k RPM with this setup. I wouldn't be shifting there all the time (more like 8.5k) but I just wanted to have the option if I wanted to when I go big turbo.
I know aluminium rods are an option for the high revving builds but does anybody know how well my setup will hold?
Thanks in advance...
Old Mar 25, 2011, 08:21 AM
still*boostn's Avatar
Def should go LR. And just curious why you would even think about going to 10k? Think some people loose the idea of over revving. Yeah its nice knowing you can,... but what turbo will you be using?
W/e your set up if going to be, get a dyno sheet for your set up and look to see if you even need to rev that high.
Old Mar 25, 2011, 12:04 PM
Liqquid's Avatar
R.P.M.
Ruins Peoples Motors
Old Mar 25, 2011, 01:15 PM
Babs's Avatar
It's definitely not a stock frame turbo...it'd comparatively be between a 35R and a 40R so it could use the extra band but I've decided not to with the info in this thread.
Old Mar 25, 2011, 10:03 PM
3grst01's Avatar
Aluminum rods need re torqued . Maybe for racing but idk if I would want to be dropping the pan on a d d. Gonna need different oil pump system for 10 000 rpm. Good luck .
mitsubeastlee
10
Sep 5, 2013 04:35 PM
babaz7
Jun 21, 2012 03:29 PM
dsevo
218
Feb 12, 2010 10:25 AM
SBR INC
Evo 'For Sale' Engine Internals and Drivetrain
12
Oct 4, 2009 08:42 PM
less10
30
Mar 13, 2009 10:19 AM
Quick Reply: High Revving Setup
