FASTEST spooling turbo capable of 700HP PLUS???
I'm looking for a bit of .2cents from the EVOM community, I'm finally done with my build, bottom end is built to handle 1000hp and high revs as it has been left a 2.0. The head is rocking stage 5 Maperformance port/polish and gsc S3 cams with behind springs & retainers, AMS vsr IM, boomba 75mm TB, full ETS Intercooler piping with 4inch intercooler, Mona Lisa Exhaust manifold, map 02 dump, fic 1850cc low Z injectors with easy tune box, AEM series 1 version 2. I wanted to break 700hp but the problem is I'm rockin the fp black with ported/coated hotside, now I'm certain I won't break 700hp without modifying the fp black which I don't want to do. Not really wanting to change my stock frame setup, so with not wanting to change I was hoping that the ATP gtx3582R is capable of doing it. ETS told me today that almost all stock frame internal wastegate turbos just can't flow enough air.
So my question is what do u guys suggest? Do u think the ATP gtx3582R can break 700hp? Also I'd like not to compromise the spoolup sped the fp black has, if there is a turbo setup that can hit 700hp and spoolup just as fast as a fp black please let me know. Thanks for the input.
the 6262 will get you there but it wont spool just like a fp but it will be close. also the gtx3582 is another way to go and it might spool better then the 62 because of the 30% more flow over the old gt35. also what type of fuel are u planning to use?
Well I'd never hit 700hp on pump, I do hVe a coolmist 50/50 water meth kit but am kinda leaning towards q16 so I can hit my mark, I'd like to have back up tune with 93 octane plus the 50/50 meth but as far as tuning with q16 plus meth, I think it would be a waste, I did mentionthe fic 1850cc low Z injectors with the easy tune box, also a bucshur double pumper, AMS file rail, fuel lab FPR -8an in and -6an out the fuel rail. There's no e85 where I'm at before anyone says go e85
One last thing, I think fic low z injectors require an easy tune box and can use q16 leaded fuel, the fic high Z injectors specifically say use with unleaded gas only no q16, if I have it *** backwards please let me know but overall what is this all about???
