apexi avcr and tial wastegates
question i have a avcr and the soleniod has 3 ports boost in boost out then the third which i believe is setup to run to the top port of a waste gate to help control boost? if this is correct does anyone have a diagram or know of how well this works? having trouble controlling boost w/ the controller
currently i have went to a mbc that feeds into the side port on the wastegate and leaving the top port VTA
but if anyone knows how to use the top port on the wastegate to help control boost w/ my EBC's 3rdport?
thanks in advance
or is this right?
currently i am trying to boost control on the bottom nipple and not doing anything on the top nipple and it seems the boost will spike but not hold
thanks in advance
or is this right?
the two are the same.. and that is how I looked my wastegate up on my EWG WRX with a stock td04. Any other method and the turbo spooled too quick for the BCS to flow air to just the bottom port. So if you hook it up direct to a boost source to the bottom port, and use the BCS to add boost to the top port, you essentially assist the spring in making more boost. This method is particularly useful when you are dealing with quicker spooling setups.
RUN FOREST RUN
Jul 13, 2008 12:24 PM
DynoFlash
10
Jan 9, 2007 12:47 PM
Blue Evo 8
Aug 26, 2006 11:56 AM
