Ever wonder what 800ft/lbs of Torque does to a transmission?
Old May 4, 2011 | 02:24 PM
  #196
Silk's Avatar
Fair enough on the ambient temps, but can't you guys come up with a bit more of an elegant solution?
Old May 4, 2011 | 02:28 PM
  #197
InsaneSpeed's Avatar
Ideally it would be mounted on the back side of the IC so you wouldn't see it, but with the fans, A/C condenser, etc.....there's just no room. We were actually going to bend up a halo that matched the perimeter of the bumper mouth and anodize it black with the IC, but we just didn't have time. We finished the entire car, changing pretty much everything in and on it including the paint color, in only 3 weeks.
Old May 4, 2011 | 02:38 PM
  #198
Originally Posted by phizzalot
Thanks for explaining . You have truly sparked my curiosity about your company
I don't know if its in the magazine but do you have the dyno sheet available to post of the 791tq curve?
Again, Sweet Build and Awesome to know of another company out there that does justice to the Evo!!!
Thank you sir. Here is the dyno graph.
Old May 4, 2011 | 02:45 PM
  #199
Pal215's Avatar
Holy Freakin ****! Just look at the jump from 4k to 5k! There is no way in hell I can imagine such force! Again Congrats guys, you've created a monster! Insane speed ftw!
Old May 4, 2011 | 03:20 PM
  #200
NorCalEvo415's Avatar
Amazing graph, great thread. Picked up 525ft/lbs between 4-5k. Just unreal numbers!!
Old May 4, 2011 | 03:26 PM
  #201
RSMike's Avatar
what was the dyno run time? (you can select the lower scale to Time)
what gear did you dyno in?
what was the ratio used?
what was the ambient temp for the run? (as recorded in the dyno)
Cheers, Mike
Old May 4, 2011 | 04:39 PM
  #202
project_skyline's Avatar
I hate dynapak's. Post up 791TQ uncorrected dynojet and then i'll give you credit.
Old May 4, 2011 | 04:50 PM
  #203
Thank you sir.
Cheers, Mike
4th gear, 4.11 gears, about 90 degrees that day.
Send us to Florida so we don't need to use the correction for our poor air, 2000ft/altitude and 100 degree heat, and no problem. Also, this was done in Arizona, not Vegas. As for additional approval, we don't need it for this car. It's already in two of the three major magazines so I guess they like what they see.
Old May 4, 2011 | 04:55 PM
  #204
turbopineapple's Avatar
And credit from you is all I ever wanted.
As soon as things slow down here I will go back to corporate Dynojet and get the Dyno sheet. But then someone will say it's not setup right, dyno operator fudged the numbers Blah, Blah , Blah. We have already stated the dyno sheet from Dynojet was just a few HP different. I know English Racing recently used the same facility....That means their numbers ar BS too right? No disrespect to English guys. Carl at Dynojet had nothing but good things to say about you guys. But this is the reason I rarely post. I don't have the patience anymore. Im off to make more fairytale tunes.
mikey
Old May 4, 2011 | 05:20 PM
  #205
mikey
I know you love the internet Mikey. The thing you forgot to say is we are going to spray the car soon as well.
Old May 4, 2011 | 06:19 PM
  #206
Migsubishi's Avatar
Damn, hopefully the fallout doesn't reach Florida
Old May 4, 2011 | 10:59 PM
  #207
GuamEVO's Avatar
Nice!!!!!!!!!!!!!!! Subscribed keep us posted on the tranny case.
Old May 4, 2011 | 11:55 PM
  #208
d613's Avatar
wow! completely shredded to pieces!!
Old May 6, 2011 | 04:47 AM
  #209
Phase one of billet housings has started!
mikey
Old May 6, 2011 | 06:07 AM
  #210
Zombie Killer's Avatar
God this is one of the coolest things I've ever read. GOOD FREAKIN JOB INSANE!!! You made that much power WITHOUT spray or meth....unfreakinreal. Can't wait to get off work so I can go find that DSport.
Quick Reply: Ever wonder what 800ft/lbs of Torque does to a transmission?
