Ever wonder what 800ft/lbs of Torque does to a transmission?
Old Apr 6, 2011, 07:11 PM
  #46
InsaneSpeed's Avatar
Originally Posted by evodan2004
does this have a shot of nitrous on it? or is this all fuel and boost
That's all boost. We have nitrous on the car, but have not shot it to date. The 80 or so people at the Modified Tuner Shootout can attest to the fact that the bottle was out of the car during dyno pulls. It's all boost on a 62mm on E85.
Old Apr 6, 2011, 07:14 PM
  #47
I suppose I can give a pic of the turbo on the car.....next to the nuclear bomb of a trans...may it RIP.
Old Apr 6, 2011, 07:15 PM
  #48
tscompusa2's Avatar
holy crap.. could be worse.. i seen a guy running 60psi and his clutch exploded and practically destroyed everything in his engine bay.
  #49
EvoDan2004's Avatar
How much boost? What was the hp
Old Apr 6, 2011, 07:16 PM
  #50
I can't give the HP of the car based on our magazine commitments, but I can tell you this.....it was more than the torque.
Old Apr 6, 2011, 07:22 PM
  #51
EvoDan2004's Avatar
What kind of dyno? This is pretty impressive
Old Apr 6, 2011, 07:55 PM
  #52
StreetThisEvo's Avatar
That does suck...I've been there many of times.
I love how people think 'building' a transmission will make them bullet proof. When you run these cars to this level **** is going to happen....period. There is no magical fluid that will save them.
Hopefully things get fixed and the car is back at it soon!!!
Old Apr 6, 2011, 08:10 PM
  #53
awdturbo8's Avatar
Holly crack. JB weld can fix that lol
Old Apr 6, 2011, 08:12 PM
  #54
Essentially identical numbers from corporate Dynojet and DynaPack.
Old Apr 6, 2011, 08:13 PM
  #55
RSMike's Avatar
would a straight cut synchro mesh gearset solve that problem?
i.e. not twisting forces from the helical cut gearset, causing the casing to split?
Old Apr 6, 2011, 08:22 PM
  #56
dbsears's Avatar
Wow I can't wait to pick this meg up. I think I remember seeing somebody that had a spare 2.4L stroker from one of their time attack cars that you did up in Vegas. I assume with that torque its a 2.4L with some serious head work and cams you got going on in there. Plus probably well over 40psi...
Old Apr 6, 2011, 08:29 PM
  #57
2.2L with under 40psi. The head is our fully CNC'd Insane Speed head.
Old Apr 6, 2011, 08:34 PM
  #58
Notch's Avatar
Awesome.
Old Apr 6, 2011, 08:36 PM
  #59
mrboost05's Avatar
We worked VERY hard to develop our Insane spec engine combination, and this was the test car for our freshly designed CNC Insane Speed ported heads. The cams are readily available and the bore and stroke is nothing anyone hasn't done before. The secret is in our head work, and the fact that Mike Angel (pioneer of turbo NSX's, Honda, Jun Racing, and of course the engine builder and tuner for FXMD's world record setting Redline Time Attack NSX....until last year...when it coincidentally stopped winning) is our in house tuner.
We currently have CNC heads for Supra, Evo 8 and GTR. These are not copied heads either. We completely redesign our heads to achieve what we are looking for. This is the first itteration based off the Mitsubishi port design. Our full bore Insane Spec head where we weld closed the ports and completely redesign the entire head with our own port design will be next in line.
sounds like the stuff my dreams are made from ive actually got to ride in a turbo nsx that mike did some work on it was a newer model yellow with hre wheels on it ive heard all about his work
  #60
EvoDan2004's Avatar
What does the car weigh
Quick Reply: Ever wonder what 800ft/lbs of Torque does to a transmission?
