Turbo fittings info needed
Old Apr 6, 2011 | 06:29 PM
jameswwt's Avatar
Hi,
im getting a GT30 series turbo and i wonder what is the different on the "Oil inlet fitting for GT28/30/35R with built-in Restrictor and Without Restrictor"?
Some said if i uses the built-in restrictor it will choke the turbo easily and some say if i dont use it, it will ruin the ball bearing CHRA as all the contaminated residue will choke the CHRA.
Thanks
Old Apr 6, 2011 | 09:40 PM
okevolutionVIII's Avatar
You should be ok, I ran a GT3076R without one and the owner of the kit before me didn't either. The oil pressure from head is so low that I can't see it being a problem.
Old Apr 6, 2011 | 11:28 PM
jameswwt's Avatar
Thanks Man...
Jaraxle
69
Nov 2, 2021 09:08 AM
XSivPSI
Dec 17, 2015 08:08 PM
ChuckP
Sep 26, 2009 02:26 AM
nickracer9
Oct 31, 2005 10:37 AM
botemarc
May 2, 2005 01:07 PM
Quick Reply: Turbo fittings info needed
