Can i advance a tooth on GSC S2 cams setting?
Hi,
i just wonder will it be safe and better to advance a tooth on the Intake cam side for a better torque response?
Or i should just stick to the GSC cams setting spec's?
The excess duration with big cams already provides an amount of IN advance and ex retard
A tooth would be way too much intake valve at overlap, might even touch. Need an adj gear and do like 1-2 crank degrees.
BTW you still get good torque with S2s IN retarded. Mine is about -5+4 (In EX).
to add response, advance intake cam
to add top end power, retard intake cam
you could advance it 1 tooth if you wanted to, it would not idle very nice though.
But you would get a sizable gain in response.
Mivec moves 30degrees, so 1 tooth is half of that
BUT it must be retuned. changing cam timing changes the engines VE
Try them without advance first and see how your setup works with the new turbo, I doubt you will need to adjust them they are great cams...
[quote=supersal;9229719]Im running S2's without Cam Gears on the std settings they work great...
Hi Supersal,
what is the power achieved on your ride on S2 2.0L?
Hi Supersal,
ruzs
Oct 19, 2004 03:00 PM
93civEJ1
17
Sep 7, 2004 12:54 PM
