Evo 5 Fuel press, Oil Press and Oil temp
Hi guys,
I recently installed some gauges into my car, and here are the readings.
The engine is stock, except for an open pod intake, adjustable fuel regulator and custom exhaust.
Cold Idle / Startup
Fuel Press: 35psi
Oil Press: 90psi
Oil Temp: umm...COLD..lol
Hot Idle (after some runs)
Fuel Press: 38psi
Oil Press: 20psi
Oil Temp: 85c
On the road (full boost @ 0.9bar)
Fuel press: 55psi
Oil press: 90psi
Oil temp: 80-90c
Are the readings normal?
Cold Idle / Startup
Fuel Press: 35psi
Oil Press: 90psi
Fuel Press: 38psi
Oil Press: 20psi
Oil Temp: 85c
Fuel press: 55psi
Oil press: 90psi
Oil temp: 80-90c
nismo3183
23
Nov 3, 2017 11:57 PM
roni4g63
15
Dec 27, 2016 09:08 AM
Profoxcg
Oct 1, 2007 07:26 PM
jbigelow
14
May 3, 2005 08:46 AM
