Built 2.0 firing on three cylinders?
So had my engine rebuilt by a local shop. When we tried starting it up it wouldn't turn. Changed out the cam sensor I believe which helped but now its only working on three cylinders if I understood correctly. My mechanic checked all the relay's and fuses, put on sparktech, but it's still having issues with one cylinder. Anyone ran into this problem before or have any guess' on what to try next?
Trying a crank sensor now see if that helps.
your best bet since its not starting pull your spark plugs check em. if your cps or cas is bad, itll either not start, or start but not run good. CPS usually is a no start, cas is usually either no start or not run well... to work out fuel issue, spray some engine start into the tb, put uicp coupler back on fire it up, if it starts great then its easier to figure out, if starts then cuts out that means its a fuel issue.
Tw3NTy0n3
May 21, 2016 11:24 PM
evillancer06
10
Dec 20, 2015 10:29 PM
Angry Slipper
Oct 10, 2010 09:28 AM
