Eagle 2.3 build issue
Hey, I recently decide to swap out my 2.0l and build a 2.3l but came across an issue which I'll share and hope you'll can help:
Eagle 100MM Crankshaft
Eagle H-beam Rods
ACL Bearings
ACL Thrust Washer
ARP Stud
Balance Shaft Kit
Wiseco HD1400 Forged Pistons
Now here's my problem, When I installed the eagle crankshaft into the block I'm getting a bit of movement (enough that i can fit to hacksaw blades between the crank and thrust washers), when i use the stock crank I'm having zero movement, what do you think is wrong here.....
Thanks in advance!!
Eagle H-beam Rods
ACL Bearings
ACL Thrust Washer
ARP Stud
Balance Shaft Kit
Thanks in advance!!
Are you using the eagle block with the evo crank? Could it be a 420a block?
Your problem isnt bearings if the stock crank doesnt have the same play. What you have is a very bad, un-usable crank. Post a pic of the crank where the thrust bearing rides. Clevites aren't thicker, you have bigger problems. Think Buschur had sum Eagle crank problems and doesnt use them anymore.
Yea i personally have used the eagle crank (well tried) and it was awful... out of round, needed massive bearings, etc. and other companies have tried to use them and no one does because of the issues. and why use it? The OEM 4g63/4 crank has been proven to be reliable at around 750hp+ cars and ABUSED HARD
SBR INC
Nov 26, 2016 07:39 AM
FS[Northeast]: built 2.0L short block, pistons, buschur intake,
O0oDC
26
Sep 3, 2015 05:46 PM
quiquepr69
Jan 16, 2012 07:55 AM
