walbro 255's limit?
Old Apr 20, 2011, 05:50 PM
stabiemcstabin's Avatar
walbro 255's limit?
Plan on making a little more power this spring and wanted to know how far can a stock walbro be pushed on e 85?
Old Apr 20, 2011, 06:08 PM
Fast_Freddie's Avatar
Depends on set up, injector size and if the Walbro is modded ... roughly about 525hp on E85 if it is modded...
Old Apr 20, 2011, 08:26 PM
son of krypton's Avatar
Once you start surpassing 400whp on a mustang dyno, the fuel pump will be your limiting factor.
Old Apr 20, 2011, 08:27 PM
2jzstang's Avatar
I usually stop around 425 wheel with E85 on a single walbro. Even if its modded.
Old Apr 20, 2011, 08:28 PM
dscevo8's Avatar
I maxed mine out at exactly 500 on E85
Old Apr 20, 2011, 08:30 PM
awdturbo8's Avatar
655 on 100oct
Old Apr 20, 2011, 08:43 PM
106rallye's Avatar
Originally Posted by awdturbo8
655 on 100oct
Isn't that a little high?
With what injectors;
Old Apr 20, 2011, 09:05 PM
Running 1200 PTE's definitely don't plan on hitting 500 maybe 460 at the most wanna not have to worry about the stock bottom end
Old Apr 21, 2011, 09:49 AM
awdturbo8's Avatar
Pte 1200. Pump was rewired with thicker wire straight from the battery
Old Apr 21, 2011, 10:09 AM
2jzstang's Avatar
You guys running (what I consider) more radical numbers (500+ E85 and 600+ other fuel), how long have you been doing this for? These seem to be pushing the pumps to the ABSOLUTE limit on the dyno, and I don't think that these are realistic street numbers for a prolonged period of time on one single walbro pump.
Perhaps I am mistaken.
Dan
Old Apr 21, 2011, 10:43 AM
awdturbo8's Avatar
I've Been doing it since November but i switched to a buschur Double pumper. I know for a fact my pump was not gonna last long at that power level. I pushed it as far as I could
Old Apr 21, 2011, 04:39 PM
SO 460awhp ON a single walbro with e85 go or a no go? As I see the Deatschwerks DW300 is claimingto handle up to 600 on e85 and way cheaper than a double pumper but no real updates yet.
Old Apr 21, 2011, 04:45 PM
awdturbo8's Avatar
I haven't seen much tests at all on the DW300. I probably missed that.
Old Nov 25, 2011, 05:01 PM
nspyr's Avatar
I am using 1000cc rc injectors and the stock walbro pump and 93oct fuel, what is the limit of the walbro pump ? Can I still get 550awhp ?
Old Nov 25, 2011, 05:57 PM
n2oiroc's Avatar
with the aeromotive and dw300 out now, it would be stupid to run a walbro for anything over 450whp. being tuned with dropping fuel pressure will bite you in the *** down the road.
hutch959
Aug 18, 2016 04:23 PM
lancerrally45
Jun 3, 2015 07:41 PM
(03evo08)
Aug 10, 2014 03:03 PM
bank277
22
Apr 15, 2010 06:51 AM
Mitchubishievo
Midwest Region
Apr 10, 2008 12:55 PM
Quick Reply: walbro 255's limit?
