Boost Leak from HELL!.. where the F*** is it
okay long story short_____________________
im in process of doing the my 1000mile break in but of course its not going to be as easy as said,.. well at least for me it hasn't been. i finally made it to 720miles just fine, SMOOTH with no issues at all and then of course i spoke to soon and my car decides to act up and mess up on me :/
as i was turning into the store while it was raining my car just randomly shuts off.. so then i go to start it back up and as soon as the revs drop the car just dies and stalls on me. so i had to manually keep the revs up above 2k to get back home..
i noticed a loud whistle sound whenever i rev'd, which lead me to believe it was a boost leak of some sort. i couldnt really listen good to see where it came from because it would just die as soon as i gave it some gas... i was able to do a boost leak test at 20psi and i heard nothing. i tried to follow the how to as best i could but still couldnt find or hear anything. did it from both tb and turbo comp side
https://www.evolutionm.net/forums/ev...g-how-why.html
suggestions:
reset iacv (waiting on my tuner to mess with it)
bad tps (not sure how to test)
replace tb shaft seal (need to send out to mil spec.. previous owner stripped butterfly screws )
check and replace injector seal (DONE fic injector to manifold seals were all cracked!)
Boost leak test (DONE couldnt find any)
Check Grimmspeed ebcs (DONE looked over the harness/pigtail and everything seems fine)
Mods
built 2.0 (720 miles on it)
stock head
fp black (720 miles on it)
speed density (tuned on it for 720 miles)
tial vta bov (tuned on for a couple of years now)
ecu flash
fic 1350 injectors (500 miles or so)
ams vsr IM
mil spec tb
buschur uicp/licp
grimmspeed ebcs
suggestions:
Mods
stock head
ecu flash
ams vsr IM
mil spec tb
buschur uicp/licp
grimmspeed ebcs
Sound like a combo of the TB shafts leaking and a bad TPS or IAC. My car was dying and stalling all of a sudden a few years back and it was the TPS.
BTW whats with a 1000 mile break in, on mine i drove it semi aggressively for the first 20 miles after it warmed up changed the oil, then got it fully tuned with no pampering or anything runs stronger and has better compression at 10k than when it had the original shortblock, changed the oil again at 500 miles and still no problems im at 15K on it now with Brad Penn oil changes every 3k miles.
http://www.mototuneusa.com/break_in_secrets.htm
and about the 1k break in .. im going with what my tuner and builder suggested .. everyone has there own ways of breakin it in
It is nothing to have a car with less than 10 miles on it at 40 psi of boost and 10,000 rpm. If it is going to fail then it is going to fail at that point and running it for 2,000 miles (whatever) easy is not going to change that. Running an engine for 2,000 miles to break it in is complete bull****. It's most companies ways of getting you to take 6 months to be ready to run the car hard and by then they hope the warranty is over.
David Buschur
David Buschur
as long as you break in your rings to seat properly....boost the **** outta it! Im file'n my ring gap 2 or 3 thousand over spec because i plan on boosting the **** outta my 2.3 and with increased cylinder pressure, ring end gap is decreased further and i dont want to blow my piston heads apart!
David Buschur
David Buschur
but all that aside^^ i appreciate the help man
update:
hey so i was looking at the tb and noticed that the iacv wasnt installed right.. the 3 bolts that held it was only held on with 2...it wasnt alighned right so it only allowed two bolts to secure it.. the 3rd was just there doing nothing.. im wondering if thats not installed and aligned right would that affect the idle?? since im having the idle issue at startup where it stalls as soon as the RPMs drop
Aby@MIL.SPEC
867
Mar 12, 2017 11:56 PM
Boosted Tuning
May 31, 2015 12:32 AM
