cel help
cel help
a friend of mine has a 06 IX and has had a problem with camshaft position sensor code it threw the code on a stock motor all the sensor where then replace no fix with that then from there the motor was pulled and built when the was finished the code was still there and is still there all the wires have been check for good connection to the ecu and to the sensor i hope someone can help me with this
