Manley turbo tuff question
Ok, so i need a little assistance from the evom guru's. First off... This has nothing to do with a long rod setup or a stroker setup. This is about the standard length rod and i am using a standard 2.0l crank.
Manley has 2 i-bean turbo tuff part numbers. 14403-4 and 14400-4. The 14400-4 is said to be used on stroker applications.
Now here is the question... Since i am not going with a stroker setup... Can i still use the 14400-4 rods?
Any help will be appreciated!
Can you please share it with as?
I am in the search for the same rods too.
The 14403-4 weight is 675gr and
the 14400-4 weight is 637gr as can be seen from Manley website.
For both the hp rate per rod is at 250hp.
From the other side i saw that carrillo pro-H with car bolts weight 560gr and are rated for 275hp per rod.But cost is almost 40% higher.
Would that 120gr per rod justify the price difference?
The plans for my built is 2lt with 6262 so not gonna rev higer than 9000rpm.
the rod for stroker is a straight I beam like crower and as mentioned lighter than the tapered beam. I would use the straight beam or better yet get Olivers.
ps. dont google image search manley rod with safe search off lmfao
![](http://www.realstreetperformance.com/ebay/manleyibeam.jpg)
FS[SouthEast]: Manley Turbo Tuff Rods
fantrman
Aug 12, 2016 10:53 AM
tkrizzy3
Oct 6, 2015 06:27 AM
bsh
Jun 6, 2013 12:49 AM
