Can i higher boost after a thicker H/Gasket?
increasing head gasket thickness is only ness if you deck the head or block, so not to change stroke/compression ratio unless u want to bend some valves.....lol has nothing to do with increase in boost. boost= higher cylinder pressure, rings need to be filed and the proper hardware needs to be used so **** stays together without warping
bigturboevo03
41
Feb 11, 2017 09:57 PM
88888
11
Jun 5, 2014 07:58 PM
Bukaj_150
May 15, 2013 09:16 PM
My03evo
Feb 28, 2013 06:28 PM
