Can i higher boost after a thicker H/Gasket?
Hi Guys,
just wonder can i higher boost when place a thicker h/gasket?
Im replacing my oem h/g to a cometic 0.51" x 86mm h/g.
But bore size is 85.5mm
Any problem for this matching?
The reason i changed my oem h/g is due to oil leak.
Not to be a jerk by any meas but start here...
http://="https://www.evolutionm.net/...-dummies.html"
Another wrong choice
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
Thanks guys as ive no choice to replace my oem hg as it is leaking....
I agree with the others. STOP any installs and get an OEM head gasket. I don't mean to scold you, but you need to do more research before you buy anything. We need to spend our $ wisely.
Yup stock hg is good up to .020 over, and my choice over the others. I see what youre saying, and theoretically yes you could run more boost, but thats not a reason to not get the stocker. And the block doesn't neseccicarily have to be pulled and decked every time because its not aluminum and doesn't warp as easy as heads do. I'd of course check it but I havnt had to re deck a block on a 4g yet, but heads yes.
