Boost!
Boost!
What is the highest boost pressure that the stock 04 Evo * motor can handle without sacrificing its reliability. Stock is 18 psi would it still be safe to go to 20 or 22?
22 psi is definitely safe, when i was on my stock 03 turbo, i went 24 psi peak held 21 to redline which is out of its efficiency range got 20+k miles out of it, but the car already had 39k when i bought it. Its all in the tune, and makin sure the engine and turbo are mechanically good then you shouldnt have an issue.
Ha your form Guam. Cool. I was there in Navy for a few yrs and saw only 2 evos there and at the time the dealer wanted 52000 for a brand new one. How many Evos are there now?
There is no longer a Mitsu dealer on guam.
Thanks for everyones input. There are no tuners on guam and my car is stock except for an ARC intake. I will set the boost at 22 psi. The car has 50K miles on it. Will this destroy my OEM BPV (plastic)?
destroy it no, but there is a chance down the road it might start leaking, you can either get a ix valve which is metal for higher boost, or eventually when it goes out look into an aftermarket one. Dont replace it until it breaks haha
How will I know if it has leaked?
usually if it doesnt hold the boost level it should be at, then usually thats a sign, stock plastic 8 diverter valves are known for leakin usually a couple pounds above stock levels.
Crazy4Cars
10
Aug 30, 2003 07:56 AM
