Difference between these head gaskets
Anybody know what the difference is in the two OEM head gasket p/n #
MN155760 and 1005A700 ? I know one is for 05-06 and 02-05 but besides that I want to know the technical difference between the gaskets, like different compression rings or something...anyone know?
Thanks
Thanks
Thanks
Thanks
You said you did some digging, can you link me where you found that info?
Thanks
here is a compare i did against an evo6 gasket
https://www.evolutionm.net/forums/ev...eadgasket.html
it was my understanding that evo8 was 4 layer, and the evo9 is 5layer.
as stated in my thread, i measured an evo9 gasket with a micrometer.
evo9 gasket is 0.9mm thick. (5 layer)
evo6 gasket is 0.62mm thick (3layer).
I have both of these at home right now if you want me to double/triple check them.
The water system in both heads are identical. I dont know why the water holes are different.
http://www.motoiq.com/magazine_artic...ided-by-8.aspx
Cheers, Mike
Cheers, Mike
EvoSeanzie
Feb 25, 2013 08:08 PM
konstantinosIX
Feb 10, 2011 07:34 AM
KY
12
Nov 29, 2010 11:46 AM
SeanC
Oct 20, 2008 05:14 PM
Sti THIS
21
Oct 28, 2007 02:04 AM
