Think this is a fire hazard?
Some people adhere heat reflective material to the oil pan, but that's a less clean solution and there is some slight advantage to retaining the exhaust heat inside the pipe.
I have some major input on this for you guys.
YES oil will catch fire. The 3" downpipes run pretty close to the pan but then again so does the stock downpipe which is even bigger than 3" with the heat shielding. The heat shielding keeps the heat down some on the stock downpipe.
IF you had a major oil leak there would be a chance of a fire with either stock or aftermarket downpipes. The chance of this would be less with the downpipe being wrapped.
Putting the stick on heat shielding on the oil pan is a GREAT way to keep the downpipe heat out of your oil, we have pieces for doing it, they are $10. This will not however cool the downpipe or lessen the chance of oil catching fire on the downpipe.
Now, in order to have a fire with the oil you would have to have a pretty severe leak, drips will not actually catch fire or atleast in all the oil leaks I have seen on DSM downpipes I have never seen a fire from it. It just burns off and leaves the downpipe black.
The only fire I have ever had was in my tube chassis car on the dyno. The oil filter had actually worked its way loose after 40+ continuos dyno pulls. The oil was pressurized at this point and spray up and onto the header. The header was unwrapped and it instantly went up in flames. It was major. Burnt the ceiling, lights, wiring harness and Tym's contact melted. It's kind of funny, Tym was right outside the car when it caught on fire I was inside with the car taken apart. There was no windshield. The flames were EVERYWHERE. Tym basically threw the laptop and hauled *** out the door. I was left in the car trying to get out and shut the car and dyno down. Once I got out I grabbed the fire extinguisher and got the fire out. I thought the entire ordeal was hilarious for some reason, Tym didn't![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Take care guys,
David Buschur
www.buschurracing.com
Take care guys,
David Buschur
I had my downpipe wrapped with DEI, when my custom turbo'ed Benz went up in a blaze I must say, it's pretty flame resistant stuff. As you can see from the pictures at:
http://www.turbobenz.com/Death.htm
The entire engine compartment was engulfed in flames for well over 5 minutes before it could be snuffed out by the local fire department.
Ultimately, I removed the downpipe when I removed parts from the car prior to letting the insurance company take it. The DEI wrap was still in good shape... only a little singed and discolored.
Pretty amazing stuff,
Jason
Jason
DrunkMunkyStyle
22
Aug 27, 2006 02:01 AM
