what turbo should i go for?
Old May 17, 2011 | 02:36 PM
safat_evo's Avatar
Question what turbo should i go for?
i have an evo 8. am thinking of going for bigger turbo but i want to ran on pump gas 91octane.which turbo should i go for tomei m7960 or fp green? my goal is 400whp for that should i change my cams?? please suggest me
Old May 17, 2011 | 03:13 PM
adam_79_2005's Avatar
fp seems to be pretty popular, either a green or red will get you there
Old May 17, 2011 | 03:18 PM
safat_evo's Avatar
should the red 1 work fine with 91octane?
Old May 17, 2011 | 03:19 PM
GrnEVO's Avatar
What's your current setup? I'd suggest skipping on the bigger turbo right off the bat. I would go with the usual start. TBE, Intake, Cams, Fuel Injectors, 255 fuel pump and tune. That's pretty much the price you're gonna pay for a turbo but you'll have better results. These cars are super simple to add power. That should get you into the mid to upper 300's. Prices will vary depending on if you find the stuff new or used.
TBE $500
Intake $200
Cams $600
Fuel Injectors $300
Fuel Pump $80
Tune $150 - $400 (depending on if you tune it or a shop)
Once you hit that number, you'll want more. Then when you have more, you'll want more. You may as well get the process started and save yourself the troubles later on.
Evosick2332's Avatar
I would say HTA Green or the Red. Def going to need cams, I would go with Kelfords 272, GSC S2, FP4rs. You will def be able to make 400 on that setup!
03evo8gsr's Avatar
green! also mite consider bbk turbo.
Old May 17, 2011 | 03:24 PM
Ghost1t's Avatar
Depends on your $ range
The FP turbos are popular , My Favorite is The FP Green
I have an FP Red for sale if you are interested
Old May 17, 2011 | 03:28 PM
GrnEVO's Avatar
Ghost, you're selling the red?
sparky's Avatar
On 91 octane I would limit my choice to one of the following three turbos:
1) CBRD BBK-Full, 2) FP HTA Green, or 3) HKS 7640R. If you want a little more topend power then I'd also include the CBRD BBK-B, and the FP Red.
Old May 17, 2011 | 03:38 PM
sparky's Avatar
In Bangladesh can you actually get 91 octane (Research + Motor/2) pump gasoline? Don't they use strictly the Research Octane Number(RON) method to rate their gasoline over there? A straight 91 octane R.O.N. pump gas would be lower octane than 91 octane R+M/2 pump gas.
Old May 17, 2011 | 03:41 PM
safat_evo's Avatar
my current setup is :
tbe
ARC intake
255 walbro fuel pump
already ordered FIC1100cc injectors
Hyper single clutch
also thinking to order s2 cams
the main problem is the fuel for that reason i am confused. will the red work fine with 91octane?
Old May 17, 2011 | 04:21 PM
GrnEVO's Avatar
tbe
ARC intake
Hyper single clutch
ok I retract my previous statement then I would go with kelford 272's or S2's and the FP Red.
Old May 17, 2011 | 05:19 PM
bonsuz01's Avatar
Go with FP's Turbo...
Old May 18, 2011 | 04:03 AM
safat_evo's Avatar
Originally Posted by sparky
in bangladesh can you actually get 91 octane (research + motor/2) pump gasoline? Don't they use strictly the research octane number(ron) method to rate their gasoline over there? A straight 91 octane r.o.n. Pump gas would be lower octane than 91 octane r+m/2 pump gas.
91 ron
Old May 18, 2011 | 04:11 AM
safat_evo's Avatar
i want to run on pump gas,is there will be any problem with the red on pump gas ???
Quick Reply: what turbo should i go for?
