Kiggly HLA Pressure Regulator Good or Bad
Any comment on this :
Any concern that it may not be cooling the valve train properly? It may not be a big issue with the relatively low lift we use, but on high end domestic motors, some companies use an oil feed in the valve cover that sprays oil on the valvesprings to insure they don't drop a valve from heat in the material.
theres a diagram in another thread about it that shows you what oiling feeds it effects. i know for a fact it does not effect the turbo feed, i cant recall what else.
Jonno99
18
Oct 18, 2015 12:35 PM
