2.4 Build
2.4 Build
Hi Everyone, so recently I have been thinking of going the 2.4 route. Can you do me a favor and just critique my build list please? I will be running an FP Black with this setup.
Here is what it is composed of:
MAPerformance Ultimate Duty Billet Steel 156mm Long Rods (Evolution 8 & 9)
-ACL 4B1146H Rod Bearings
- Advanced Ceramic Rod Coatings
ACL Race Main/Thrust Bearings
AWD Spec Wiseco HD Pistons
ARP Rod Bolt Kit (DSM / Evo I-X)
ARP Main Studs
Also which head gasket is the best for a 2.4 and what type of machine work would I need? ie: Would I have to bore the stock block out more and if so how much and anyone know what the cost of the machine work usually runs?
Thanks.
ARP Main Studs
Thanks.
sounds ok to me compression?? also if you get the 4g64 block then not much machine work needs to be done besides cleaning and placing everything together. You did not mention a crank are you using stock 4g64 or getting a eagle etc. What about the timing belt situation vs getting camgears for the water pump are you getting the custom bracket or weilding one in. Those are other questions that you did not ask or state.As for the headgasket you should definatly get the AMS custom 4g64 gasket for the evo its 165 shipped and will seal perfectly.
Also does anyone know where I can get a 4g64 balance shaft eliminator kit? And is it worth it?
Thanks for the input!
Thanks Rockman. I will be using aftermarket cam gears and getting the AWD Motorsports Evo 8/9 2.4L Water Pump Spacer. I will be using the stock crank. And would I have to buy a 4g64 timing belt or can I use my current one, which is fairly new. I need to find out from mike@awd, what the compression is on those pistons, but I am aiming in the range of 9.0:1-9.5:1. My car will be running dual maps of 91 oct and e85.
SBR INC
22
Jul 27, 2010 11:33 AM
SBR INC
62
May 19, 2010 12:46 PM
SBR INC
Nov 12, 2009 06:18 AM
SBR INC
13
Nov 9, 2009 08:38 AM
gl4662
For Sale - Cars For Sale
27
Feb 29, 2008 04:27 PM
