Exedy Twin too much for DD?
#46
#47
I would guess that most people on this board always have the intension of making more horsepower. I would say you can expect the stocker to start letting go in the 300AWHP area once you start getting to the track and depending on driving style. So why not go with the twin early and have the clutch to go with the power down the road?
I have resolved my issue. Having excess knowledge available on potential failures such as dragging clutches and worn out master and slave cylinders was the worst case scenario, based on the given symptoms. This had me losing sleep thinking I was going to have to get under the car and pull the trans again...When all it required was a good bleeding and a little pedal adjustment for good measure. I believe the combination of not having it bled in a year plus in addition to probably having introduced some more air while doing the brakes was the culprit...hope others are as lucky as me.
Cheers
Cheers
#49
Seems as if an Exedy Twin is a great clutch for a DD.... I drove my friend's Evo 8 a few years back that made around 440'ish at the wheels, and if I remember correctly, the clutch was very light and easy to drive.
I recently put an Exedy stage 1 in my car, and I was just curious how the two compare. I went stage 1 because I'm only around 350 WHP and don't plan on doing anything crazy to get big HP #s... The clutch is a little stiffer, has more chatter, and just not as "stock feeling" as I thought it would be.
I'd hate to have to go back and pay the labor, try to resell my near new Exedy, etc., but I'm just wondering what people thought of how the two compare. The shop put down "Stage 1.5" on the bill, so I'm not sure what this means, and haven't had the chance to ask them about that. Any input is appreciated!
Trevor
Trevor
rs03evo
Jan 5, 2011 04:24 PM
Boosted20
Jun 22, 2008 04:59 PM
Johnboy1065
11
Apr 3, 2007 08:48 PM
smackdaddy
Mar 10, 2004 09:34 PM
