What cams for HKS 7460 turbo?
Old Jun 10, 2011, 02:11 PM
KakimotoRR's Avatar
Which your opinion ? I have too many choices but which better?
thanks
Mauricio Evo IV's Avatar
Kelford 272´s
Old Jun 10, 2011, 02:54 PM
MikeB@FFTEC's Avatar
Kelford 272s are always great. There are also the new HKS cam grinds 274/278 for the 8 and also GSC S2 if you can find them in stock.
Old Jun 10, 2011, 03:06 PM
SRToad4's Avatar
My buddy runs the HKS turbo, GSC S2's, 1450's, speed density, e85, and puts down 450/430 (torque kept low so that the stock block holds together)
Old Jun 10, 2011, 03:24 PM
blackenedwings's Avatar
Kelford 272s or GSC S2s are the forum favorites for most setups. Larger displacement motors (2.3/2.4) are going to want something more aggressive.
Old Jun 10, 2011, 03:28 PM
MR BURTON69's Avatar
Fp4r
Old Jun 10, 2011, 06:21 PM
sparky's Avatar
What about the GSC S3 cams? Everyone raves about the S2's, but I am curious about the S3's myself.
Which of these two GSC cam grinds would work better with a fully ported cylinder head? What else is needed besides retainers and springs to be able to run the S3's?
Old Jun 11, 2011, 08:47 AM
evo8426's Avatar
I thought a built motor was necessary to run the S3's because they have such a high lift that would put the valves into the top of the piston.
Old Jun 11, 2011, 09:06 AM
b16a2delsol's Avatar
Why would a built motor change the piston clearance?
Old Jun 11, 2011, 09:10 AM
evo8426's Avatar
Piston being designed for the valves to travel further into the combustion chamber, Wiseco calls them valve pockets
Old Jun 11, 2011, 09:26 AM
Thats what I thought you meant . But then I was thinking I really only see those on an all motor setup.
Old Jun 11, 2011, 10:02 AM
The S3 also have a much longer duration as well. It's not just the lift that would factor into cam selection, but also the type of motor and how high you plan on revving it as well. With a turbo like the HKS, you would want a cam to take advantage of the quicker spooling capabilities like a 272 or equivalent. A 280 camshaft would work better for a higher revving or big turbo motor that would carry the powerband in the upper RPM range.
Old Jun 11, 2011, 10:37 AM
tiggeryellow1's Avatar
+1... What are your intentions for this car? I see in your signature that you have the "Fastest EVO Drag car in Europe" soooooo is this a drag car? Or a DD that you also drag? Do you do Auto-X? I need some more information.
Old Jun 11, 2011, 04:45 PM
KakimotoRR's Avatar
We had the fastest drag evo in the europe from Greece...Now it's not!!!
https://www.evolutionm.net/forums/au...-drag-evo.html
My question about the cams is for the other project...
Old Jun 11, 2011, 05:07 PM
blknblubkrdude's Avatar
The S2's are a great cam, along with the Kelfords. Honestly I would not pair them with a turbo like the HKS, that is aimed towards quick spool and fast response.
Quick Reply: What cams for HKS 7460 turbo?
